Wet Tile Saw Chipping - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-21-2013, 08:40 PM   #1
Rewards Points: 150
Wet tile saw chipping
So I used a wet tile saw for the first time. Was simple enough but was getting a little more chipping on the cut edge than I would like. Any advice for keeping the edge as chip free as possible?
Arsinek is offline   Reply With Quote
Old 07-21-2013, 08:46 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,362
Can't tell exactly... but you said for the first time... i
s it a new big box saw.... the blades that come with them are crap...
it is worthwile to buy a good blade if the tile/application require a good cut... I KNOW THEY ARE EXPENSIVE... AND LOOK THE SAME AS THE CHEAP.
Slow feed also helps some.
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 07-21-2013, 08:51 PM   #3
DIY staff
Rewards Points: 7,174
Adding to Mountains observation----the blade must be in line with the table--adjusting the table slide is important---
What style of saw?
Also---some tile just like to chip---
Old 07-21-2013, 09:07 PM   #4
What style of saw?
YUP..... Just as Mike says....And you can get a sandstone... which won't sand it but will debur it, unsharpen it sorta of
Also. I get off the internet sanding belts (can;t remember the grit name) that will take down ceramic, porceline a little, and softer stones , marble and some softer granites.
Best
Old 07-26-2013, 06:14 AM   #5
Rewards Points: 150
The saw is a friends which he got from a flooring place, I think it was the cheapest one they had. I went and bought a new blade, a QEP black widow. Hopefully it helps.
Old 07-26-2013, 06:24 AM   #6
DIY staff
What kind of saw?
Blade over a sliding table?
Blade under the table?
Bridge saw with motor and blade on long track above stationary table?
Old 07-26-2013, 06:26 AM   #7
Rewards Points: 150
What kind of saw?
Its almost identical to this one....
http://www.amazon.com/Master-Cut-600...4837977&sr=1-4
Old 07-26-2013, 06:39 AM   #8
DIY staff
Blade under the table----
The fence is hard to align with that type--so some chipping will accure--
Most cuts are hidden so that might not be to big a problem----Just take extra care setting the fence when making a 'show cut'---
Old 07-26-2013, 09:19 AM   #9
Rewards Points: 5,978
Those saws a known for being bad the fences won't align and stay aligned. They have horrible blades, in other words there is a reason they are $50. Having said that let me add I have one, I use it for repair jobs of maybe 1 or 2 tile. If your project is larger or you want better I would suggest renting a saw.
Old 07-26-2013, 10:36 AM   #10
Rewards Points: 150
Well just tried my fancy $30 blade no difference.
What are some things I can use to sand down the edge of the tile?
Old 07-26-2013, 11:02 AM   #11
Rewards Points: 6,652
It really depends on how fast you are going, the material you are cutting, rpm of the motor spinning the blade.
I have never had issues using the Tile saw I got from Harbor Freight.
Make sure you have the blade installed in the correct direction of spin, and also make sure you have enough water in the container, and also you can wet down te tile first with a cup of water before cutting.
Old 07-26-2013, 02:11 PM   #12
Rewards Points: 150
I could definitely be doing something wrong, of course theres no way for me to tell.
The tile is 18 inch floor tile, the box says porcelain but the center of the tile is brown which I thought porcelain carried the surface color through the whole tile which this stuff doesn't.
As far as speed I was pushing it through at a crawl. I just tried going faster and the result was no different.
The water is just below the max marking.
At this point it doesnt matter because this morning I went out and bought this....
http://www.homedepot.com/p/BRUTUS-20...3#.UfLJR21ugqk
And man, theres no comparison, the manual cutter I might get one small chip per tile, most have had no chips. And I just started using it so once I get the hang of it chips might be rare.
So Im using the wet saw for irregular cuts.
I also bought a small sanding stone designed for tile and I find it to be too smooth. Its almost more like a polisher.
The Following User Says Thank You to Arsinek For This Useful Post:
ToolSeeker (07-29-2013)
tile shower replacement with new tile Axhammer Remodeling 86 08-19-2013 07:22 AM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 02:02 PM
