-   -   Wet tile saw chipping (http://www.diychatroom.com/f15/wet-tile-saw-chipping-184002/)
Arsinek 07-21-2013 08:40 PM
So I used a wet tile saw for the first time. Was simple enough but was getting a little more chipping on the cut edge than I would like. Any advice for keeping the edge as chip free as possible?
MTN REMODEL LLC 07-21-2013 08:46 PM
Can't tell exactly... but you said for the first time... i
s it a new big box saw.... the blades that come with them are crap...
it is worthwile to buy a good blade if the tile/application require a good cut... I KNOW THEY ARE EXPENSIVE... AND LOOK THE SAME AS THE CHEAP.
Slow feed also helps some.
Best
oh'mike 07-21-2013 08:51 PM
Adding to Mountains observation----the blade must be in line with the table--adjusting the table slide is important---
What style of saw?
Also---some tile just like to chip---
MTN REMODEL LLC 07-21-2013 09:07 PM
What style of saw?
YUP..... Just as Mike says....And you can get a sandstone... which won't sand it but will debur it, unsharpen it sorta of
Also. I get off the internet sanding belts (can;t remember the grit name) that will take down ceramic, porceline a little, and softer stones , marble and some softer granites.
Best
Arsinek 07-26-2013 06:14 AM
The saw is a friends which he got from a flooring place, I think it was the cheapest one they had. I went and bought a new blade, a QEP black widow. Hopefully it helps.
oh'mike 07-26-2013 06:24 AM
What kind of saw?
Blade over a sliding table?
Blade under the table?
Bridge saw with motor and blade on long track above stationary table?
Arsinek 07-26-2013 06:26 AM
Originally Posted by oh'mike (Post 1221105)
What kind of saw?
Its almost identical to this one....
http://www.amazon.com/Master-Cut-600...4837977&sr=1-4
oh'mike 07-26-2013 06:39 AM
Blade under the table----
The fence is hard to align with that type--so some chipping will accure--
Most cuts are hidden so that might not be to big a problem----Just take extra care setting the fence when making a 'show cut'---
ToolSeeker 07-26-2013 09:19 AM
Those saws a known for being bad the fences won't align and stay aligned. They have horrible blades, in other words there is a reason they are $50. Having said that let me add I have one, I use it for repair jobs of maybe 1 or 2 tile. If your project is larger or you want better I would suggest renting a saw.
Arsinek 07-26-2013 10:36 AM
Well just tried my fancy $30 blade no difference.
What are some things I can use to sand down the edge of the tile?
gregzoll 07-26-2013 11:02 AM
It really depends on how fast you are going, the material you are cutting, rpm of the motor spinning the blade.
I have never had issues using the Tile saw I got from Harbor Freight.
Make sure you have the blade installed in the correct direction of spin, and also make sure you have enough water in the container, and also you can wet down te tile first with a cup of water before cutting.
Arsinek 07-26-2013 02:11 PM
I could definitely be doing something wrong, of course theres no way for me to tell.
The tile is 18 inch floor tile, the box says porcelain but the center of the tile is brown which I thought porcelain carried the surface color through the whole tile which this stuff doesn't.
As far as speed I was pushing it through at a crawl. I just tried going faster and the result was no different.
The water is just below the max marking.
At this point it doesnt matter because this morning I went out and bought this....
http://www.homedepot.com/p/BRUTUS-20...3#.UfLJR21ugqk
And man, theres no comparison, the manual cutter I might get one small chip per tile, most have had no chips. And I just started using it so once I get the hang of it chips might be rare.
So Im using the wet saw for irregular cuts.
I also bought a small sanding stone designed for tile and I find it to be too smooth. Its almost more like a polisher.
