Wet Spots Seeping Thru Joint Compound - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 01:08 AM   #1
wet spots seeping thru joint compound
we poppet off OLD plastic wall tiles from kitchen walls. Patched holes and smoothed wall with joint compound ,we are seeing brown spots coming thru. the original wall is plaster. the house is old with no basement.
lida is offline   Reply With Quote
Old 09-10-2011, 05:25 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
You have a question?
Most likely , you are seeing the old glue bleeding through
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
oh'mike (09-10-2011)
Old 09-10-2011, 06:32 AM   #3
DIY staff
Rewards Points: 7,174
Prime it with a stain blocking primer.
Old 09-10-2011, 04:21 PM   #4
Use Kilz...it will cover just about anything!
Rklaiss is offline   Reply With Quote
dots in joint compound insearch Painting 2 06-01-2011 10:44 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 06:57 PM
