We Want To Add Another Bathroom ...what Materials We Need? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-26-2014, 12:34 PM   #1
Rewards Points: 71
Question
We want to add another bathroom ...what materials we need?
We want to add another bathroom and would like to know what material we need?
Please add to following.
1.Bathtub
2.vanity with sink and faucet
3.toilet
4.tiles
5.small window
5.Bathroom door
6.Fan
7.lighting fixtures
vikasintl is offline   Reply With Quote
Old 06-26-2014, 12:44 PM   #2
DIY staff
Rewards Points: 7,174
Protection--tarps and carpet protector
framing lumber
plumbing and drain and vent piping
shower mixer valve
electrical rough in supplies
insulation
drywall
cement tile backer for walls and floor
base and case moldings
ducting for the fan
paint--tile setting mud and grout
mirror/tub doors or curtain
towel bars/TB holder
paint
Old 06-26-2014, 01:28 PM   #3
MarginallyQualified
Rewards Points: 2,464
The difference between these two posts?
One is the sizzle and the other is the steak.
Old 06-26-2014, 01:39 PM   #4
DIY staff
I had a potential customer think I was gouging him on a 1960.s house bath gut--adding all new plumbing and cutting a window into antique siding--
"That's to much! I'm buying all the expensive stuff ! You are just buying some 2x4s and drywall!"
(he also asked if he could use my dumpster to get rid of the demolition debris)
Old 06-26-2014, 02:12 PM   #5
Rewards Points: 144
Where is the bathroom going to located?First floor?Second floor?Slab house?Cralwl space?Basement?How far from existing plumbing?
This is an impossible question to answer with the information you have given.
mako1 is offline   Reply With Quote
Old 06-26-2014, 03:45 PM   #6
Rewards Points: 660
Tarheel, you can stop posting now. You will never top this post.
B
Beepster is offline   Reply With Quote
The Following User Says Thank You to Beepster For This Useful Post:
oh'mike (06-27-2014)
Old 06-26-2014, 05:08 PM   #7
Rewards Points: 13,300
No one here knows what the layout of your house is, size of floor joist, spans, spacing's, location of drains, what the drains and supply's are made of, construction of the home, what type siding you have, what your local zoning codes are.
Adding a bathroom opens up a whole can of worms when it comes to zoning.
Biggest issue will be drainage, supply lines are easy, drains need proper slope, venting, sizing ECT.
Old 06-27-2014, 08:22 AM   #8
Rewards Points: 514
Exhaust fan timer switch. Wire for power/neutral and ground. GFI outlet and double if for bedrooms. I also have separate outlet near the toilet for possible heated seat, bidet, blank cover if unused.
Installing screw blocks for towel bars, safety grips, etc.
Solid brass or stainless door hinges.
Medicine cabinet with decent hinges. Even Kohler, check reviews for complaints.
carpdad is offline   Reply With Quote
Tags
bathroom , remodelling
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 08:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 05:22 PM
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 11:50 AM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
Unsure of bathroom materials lavender11 Remodeling 4 05-31-2006 06:05 PM
