We Just Bought A House And Are Thinking About Remodeling The Bathroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-28-2008, 04:12 AM   #1
We just bought a house and are thinking about remodeling the Bathroom
We just bought a house and we are thinking about remodeling the Bathroom. I enjoy very hot and steamy showers. I will install a large vent fan through the attic and out the roof but it would only be used after the shower is complete, NEVER DURING.
First, Demo the room down to the studs and joists.
After that, I was thinking of using a moisture barrier inside all six faces of the room and cutting slits into the floor side to allow for drainage of possible condensation.
Then I would lay down a couple of layers of Hardie 500 board (glue under the first set and thinset and tape under any others) and maybe a backer board to replace the sub-flooring (depending on the current floor thickness). The finished flooring would be Vinyl.
Lastly, I would also use Backer board on the walls and ceiling. They would be painted with a good, rubber based paint.
Any ideas on if,
this is doable
or,
any reasons on why I shouldn't?
Kellir is offline   Reply With Quote
Old 11-28-2008, 10:04 AM   #2
Drywall contractor
Rewards Points: 1,070
Slits in the floor to drain where??? The basement/crawl space? Not a good idea. Just asking for mold problems, for one thing. Laminate is not a good idea in wet areas.
You just need to build a steam enclosure for your shower.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-28-2008, 10:18 AM   #3
You lost me, too, on the drainage slits. When you say laminate, are you referring to the fake wood floors, or lanolium? Either way, with all the work you're doing, I'd do tile.
For the ceiling vent, make sure to run that through the attic and out the roof. Don't just vent it into the attic.
Jeeper1970 is offline   Reply With Quote
Old 11-28-2008, 05:59 PM   #4
I made a few changes to my 1st post. I hope that helps to clear things up.
Vinyl, not laminate. Darn typos
I will.
Old 11-28-2008, 10:51 PM   #5
Registered User
Termite's Avatar
You're trying to re-invent the wheel. I'd suggest sticking to more conventional, proven methods.
Old 11-29-2008, 04:38 AM   #6
I have damaged conventional, proven methods a few times over the years. I want something better that can handle me for my own house.
Old 11-29-2008, 09:41 AM   #7
I, too, am confused as to where the water from the slits is going to go to. Your first major mistake is not running the exhaust fan "during" the shower. You are allowing steam to turn to drops, that will not be taken out of the room. If you have "damaged conventional methods", I would go back and make sure you you performed them correctly.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-29-2008, 10:30 AM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Maybe you should install a steam sauna. It's designed for what you want.
Edit: Another idea, maybe you can wrap the entire bathroom with a membrane as if the entire bathroom is a shower using a product like Shluter Kerdi.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-29-2008, 08:47 PM   #9
Rewards Points: 162
Any ideas on if,
this is doable
or,
If you are installing a vinyl floor, I wouldn't waste your time on Hardie backer board. Put down a good sanded plywood over your subfloor. Build the shower properly and you won't have to worry about condensation.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 07-16-2009, 08:54 AM   #10
I think you done a good job and need some appreciation rather then regression and I think you have made a well designed bathroom and even then if you think you need some more help to change what have you done you can easily go to LINK REMOVED
AngelleMarshall is offline   Reply With Quote
Old 07-16-2009, 09:01 AM   #11
Registered User
Termite's Avatar
Spamming this site will not be tolerated.
