Waterseal Poured Foundation - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-23-2007, 09:27 PM   #1
Question
Waterseal poured foundation
I have a couple cracks in my foundation and i want to waterseal the poured foundation i wanted to know if anyone knows what the best products are for that
ktwags is offline   Reply With Quote
Old 04-24-2007, 06:36 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
For structural repairs; Concrete Epoxy resin is the component to use. There is some preperation involved.
It is injected into the crack and forms a super strong bond with the concrete, often stronger than the material it is injected into...
Here is a discussion:
http://www.askthebuilder.com/B119_Co...y_Repair.shtml
Here is a link:
http://www.abatron.com/home006.htm
- Build Well -
Old 04-24-2007, 08:28 AM   #3
what can i do for waterseal then after i use the concrete apoxy?
Old 04-24-2007, 09:17 AM   #4
Rewards Points: 1,088
I've had the concrete epoxy done at my house. Small cracks were cleaned up, and small holes were drilled along the crack where the epoxy was injected. Construction adhesive/caulk is then applied over the crack. For larger cracks, you can clean up the crack and apply a hydraulic cement.
Waterseals are generally used for concrete block foundations, not poured foundations. Given that, a brand would be "Drylock," which can be purchased at home centers like Lowe's.
http://www.ugl.com/drylokMasonry/mas...ofer/index.php
handy man88 is offline   Reply With Quote
Old 04-24-2007, 09:39 AM   #5
Some points to consider:
http://www.concretesealants.com/basement.htm
Some of the products out there:
http://www.radonseal.com/concrete-sealers/siloxanes.htm
http://www.radonseal.com/concrete-sealers/lastiseal.htm
- Build Well -
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
Math check on amount of concrete for poured foundation? Badfish740 Building & Construction 10 05-05-2007 07:49 AM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
re-enforcing foundation - southern cal jhb Building & Construction 1 10-02-2006 01:15 AM
