-   -   Waterseal poured foundation (http://www.diychatroom.com/f15/waterseal-poured-foundation-7974/)
ktwags 04-23-2007 08:27 PM
I have a couple cracks in my foundation and i want to waterseal the poured foundation i wanted to know if anyone knows what the best products are for that
AtlanticWBConst. 04-24-2007 05:36 AM
For structural repairs; Concrete Epoxy resin is the component to use. There is some preperation involved.
It is injected into the crack and forms a super strong bond with the concrete, often stronger than the material it is injected into...
Here is a discussion:
http://www.askthebuilder.com/B119_Co...y_Repair.shtml
Here is a link:
http://www.abatron.com/home006.htm
ktwags 04-24-2007 07:28 AM
what can i do for waterseal then after i use the concrete apoxy?
handy man88 04-24-2007 08:17 AM
I've had the concrete epoxy done at my house. Small cracks were cleaned up, and small holes were drilled along the crack where the epoxy was injected. Construction adhesive/caulk is then applied over the crack. For larger cracks, you can clean up the crack and apply a hydraulic cement.
Waterseals are generally used for concrete block foundations, not poured foundations. Given that, a brand would be "Drylock," which can be purchased at home centers like Lowe's.
http://www.ugl.com/drylokMasonry/mas...ofer/index.php
AtlanticWBConst. 04-24-2007 08:39 AM
Some points to consider:
http://www.concretesealants.com/basement.htm
Some of the products out there:
http://www.radonseal.com/concrete-sealers/siloxanes.htm
http://www.radonseal.com/concrete-sealers/lastiseal.htm
