Waterproofing Transition From Wall To Tub With No Flange - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-15-2008, 02:40 AM   #1
Waterproofing transition from wall to tub with no flange
I sure hope someone can help.
I have a cast iron tub with NO FLANGE.
I want to make a tiled shower enclosure but I don't
know how to handle the transition between the tiled
wall and the bathtub, so as to avoid any moisture
slipping behind the wall.
Any suggestions? Sure would appreciate it.
Big John is offline   Reply With Quote
Old 03-17-2008, 12:44 AM   #2
Depending on what you intend to use for waterproofing...If it's going to be normal building paper as a vapor barrier I would take my time and use contact cement or similar to glue the paper to the tub where it meets the framing. Take care to leave enough slack so that when you set the cement board down, it doesn't tear the paper. You can cut off the excess paper after you install the cement board. I would then seal the joint between cement board and tub with silicone caulk before installing tile.
If you are going to use Kerdi, I would do the same thing with it except it goes on OVER the cement board. I would still caulk the cement board first, then glue the Kerdi to the tub with contact cement...then caulk the tile to the tub....keep on top of the tile caulking for the rest of your life.
send_it_all is offline   Reply With Quote
Old 03-17-2008, 01:01 AM   #3
Boz
Gus
Boz's Avatar
Without a flange, this is the key.
Boz is offline   Reply With Quote
Old 03-17-2008, 01:15 AM   #4
ICF Construction
Purchase a flange kit
Most tub manufacturers make them for situations like this
Chris
Chris Johnson is offline   Reply With Quote
Old 03-17-2008, 02:01 AM   #5
Hey everyone!
Thanks for the suggestions. I sure do appreciate it.
Old 03-17-2008, 02:51 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Big John,
Look into what Chris Johnson suggested: Optional Tile Flange Kit for tubs.
Try this: http://jacuzzi.com/home.php
See Diagram on Page 9 of 32, RIGHT side schematic (PDF file): http://www.jacuzzi.com/pdf/ASTERIA.PDF
- Build Well -
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
