Waterproofing New Tub - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 08:56 PM   #1
Rewards Points: 14
waterproofing new tub
Hey guys Im remodeling my bathroom and its a total gut and rebuild. I'm about ready to install the tub but have a few questions i want to make it as waterproof / water tight as possible. I'm going to be tileing inside the shower. this is what i plan on doing please help me figure out if what i'm doing is ok or if i need to make changes. I plan on installing the tub than installing a plastic vapor barrier directly on the studs behind than I plan on installing cement backerboard, and than i plan on installing a waterproof membrane on top of the backerboard like (LATICRETE Hydro Ban) or (Red Guard) something that can ust be painted on and than I plan on installing the tile directly over that. How does this sound I want to make sure it's as water proof as possible any help or pictures would be great
b16bri is offline   Reply With Quote
Old 04-25-2013, 09:03 PM   #2
Trucon01's Avatar
Rewards Points: 510
I don't think that will work well. You would have a double vapor barrior... Either use the plastic or the Hydroban / Redgard. I used Redgard for my bathroom shower...
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
The Following User Says Thank You to Trucon01 For This Useful Post:
JazMan (04-26-2013)
Old 04-25-2013, 09:31 PM   #3
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
There is not limit to the amount of effort you can use to waterproof a shower wall... and at the end, there's no guarantee it won't eventually leak.
30lb Felt paper over the studs would be better/more durable than plastic. I see no need to apply a second membrane over the backer board. It might actually cause some adhesion problems over time on the wall. For added sealing, use a good sealer over your grout and you should have a well built shower wall.
You reference both a shower and a tub in your question, so I'm unclear as to the floor of the project.
Hope this helps,
InspectorZo
Nailing problems and building solutions.
Facebook | Twitter
InspectorZo is offline   Reply With Quote
Old 04-25-2013, 09:42 PM   #4
DIY staff
Rewards Points: 7,174
Waterproofing the board is the best insurance you can get---backer board and tile are not water proof---
Some water can and will get behind the tile--so waterproofing the face of the board is the best plan---
Sealers do not waterproof the grout---their only purpose is to make the grout less likely to stain---
JazMan (04-26-2013)
Old 04-26-2013, 06:39 AM   #5
Rewards Points: 14
The floor will be a tub I just call it a shower out of habit lol thanks for all your input I like the idea of the waterproof membrane (red guard) on the backer board but if I go that rout is the barrier or felt on the wall needed or even a good idea at that point what else can I do to help this issue ?
Old 04-26-2013, 06:56 AM   #6
DIY staff
When you waterproof the face of the board--no vapor barrier is needed on the studs---
That is considered a double vapor barrier and is not good---
JazMan (04-26-2013)
Old 04-26-2013, 07:51 AM   #7
Rewards Points: 14
Ok thanks for your help now what about insulation do I need to install it ? the tubs on on interior wall but is butted up to the exterior wall normally aren't you suspost to have a barrier when you install insulation. Thanks for you help this will be my first bathroom
Old 04-26-2013, 10:27 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 346
I agree that a surface membrane is by far the best way to go and never use both surface and plastic or tarpaper over the studs. BTW, tarpaper is not a waterproofing, nor is it a vapor barrier. At best it's a vapor retarder, it's permeable.
In the case where there is faced insulation for an outside wall, I would simply slash the facing and let it breathe.
Vapor barriers are a very confusing subject and their use can vary by location. Where you live might matter, so a call to your town's building department may help.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (04-26-2013)
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Why I can't use thin-set mortar over RedGard waterproofing membrane? sukhenkoi Kitchen & Bath Remodeling 9 03-16-2013 02:39 PM
Stone Basement Waterproofing / Foundation Footings? troyce1 Concrete, Stone & Masonry 1 02-26-2012 10:11 PM
Conditioned Crawl Space - Advice re Waterproofing AND Int or ext insulation JohnNe Building & Construction 4 02-10-2012 06:53 AM
