Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-03-2009, 07:28 PM   #1
waterproofing an all tile shower
I noticed the wall tiles around the base of my walk in shower were coming loose. They used greenboard and no vapor barrier. The tile floor is still intact but the walls have to be replaced,(moldy). I was going to use durock but I can't figure out how to get a good seal around the bottom without a liner. The wall behind the greenboard is cinder block with a few thin strips of wood glued on to screw into, will this hold durock? and if I need to put more wood strips up what glue should I use? I need all the help I can get.
determined1 is offline   Reply With Quote
Old 03-04-2009, 07:42 AM   #2
You would mechanically attach the wood to the block wall, don't just use adhesive. Use tapcons and screw into the mortar joints.
You need to mention what sort of shower base you have for the other issue.
Ron
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 09:19 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 01:27 PM
