Waterproof Bathroom Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-30-2008, 04:07 PM   #1
Question
Waterproof bathroom window
Would like to replace 5" bathtub with an enclosed shower, but have a doublehung window directly above the tub. Are there any waterproof or waterresistant windows on the market. Or are there other solutions other than the obvious (remove window).
Swansdown is offline   Reply With Quote
Old 08-30-2008, 04:34 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use a vinyl window (no wood). Install PVC composite material for the jambs and all the trim work. When installing the window stool (interior sill), slightly pitch it for water drainage. Use mold/mildew resistant caulking.
- Build Well -
Old 08-30-2008, 04:39 PM   #3
the Musigician
DangerMouse's Avatar
but if you take out the 5 inch tub, where will Barbie take her bath? j/k do what Atlantic said and you'll be set.
Old 08-30-2008, 10:56 PM   #4
Rewards Points: 2,906
Another option would be to just go to any home center and buy those self adhesive magnetic strips. Basically, it's a metallized rubber material that's magentic, and it has a peel away adhesive backing on one side.
Stick those magnetic strips to your wall above and on both sides of the window.
Stick similar magnetic strips to some plastic or even shower curtain material.
Install the shower curtain over your window. If it's made out of a clear plastic, then you don't even need to remove it between showers.
Nestor_Kelebay is offline   Reply With Quote
Old 08-31-2008, 07:05 AM   #5
Whatamess
I had the same situation and I filled it with glass block.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-31-2008, 10:40 PM   #6
couldn't even wash my winkie in a 5" tub
yesitsconcrete is offline   Reply With Quote
Old 09-01-2008, 06:34 AM   #7
Such a method would create an area that will still receive moisture vapor and trap it. A "moisture-vapor-envelope".
Such a design would be virtually guaranteed to become a breeding ground (area) for mold and mildew. Areas in damp or moist envrionments need to be open, to allow moisture to vacate (air circulation), not seep into the space, and get trapped.
- Build Well -
Old 09-01-2008, 10:33 PM   #8
If mildew were to become a problem, the plastic over the window could be removed and the window cleaned. Mildew is not at all hard to kill with bleach.
window in bathroom, or not? johnny331 Remodeling 18 08-10-2010 01:40 PM
Window in Bathroom Shower: MOLD roztom Building & Construction 25 08-27-2008 05:42 PM
Create Window in Master bathroom bladesj Carpentry 2 08-12-2008 09:43 PM
Installing New Bathroom Window 1L243 Building & Construction 4 01-26-2008 11:40 AM
Sorta waterproof window for OVER a tub shower bathroom justdon Remodeling 5 09-16-2007 08:27 PM
