Waterproof Bathroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 12:21 PM   #1
Rewards Points: 99
waterproof bathroom
Planning on gutting bathroom and tiling walls. After I gut the walls down to studs, I was planning on stapling felt paper as a moisture barrier and then hardy backer. After research I discovered redguard. With redguard can I skip felt paper? Was thinking just putting up hardibacker directly to studs, then applying two coats of redguard. Does this sound accurate? Thank u all in advance!!
er78mph is offline   Reply With Quote
Old 12-18-2012, 08:03 PM   #2
Rewards Points: 14,312
Use the red, leave out the black.
Never want to have two vaper barriers.
Old 12-18-2012, 09:35 PM   #3
Rewards Points: 240
check out "kerdi"
Fix'n it is offline   Reply With Quote
Old 12-18-2012, 10:04 PM   #4
Originally Posted by Fix'n it View Post
check out "kerdi"
Thats what we did in our recent bathroom reno. I had never heard of it previously but in my research in stood out as the best option.
sjdawg is offline   Reply With Quote
Old 12-19-2012, 06:52 AM   #5
Its the best option so far from what I read recently...
CharlotteTaylor is offline   Reply With Quote
Old 12-19-2012, 11:03 AM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
If you are talking about a shower, the previous posts are right on.
If you are talking about bathroom walls, waterproofing to that degree is not really necessary.
gutting bathroom debiasio Remodeling 30 02-17-2011 02:32 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 07:13 PM
Bathroom Venting on Septic System edro Plumbing 2 01-03-2011 07:41 AM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
Sorta waterproof window for OVER a tub shower bathroom justdon Remodeling 5 09-16-2007 08:27 PM
