Water Leaking Around Window In Tub/shower Surround - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-21-2014, 06:17 PM   #1
Water leaking around window in tub/shower surround
We have an older home with an upstairs bathroom that just had a tub (no shower) with a window that was approx. 38" above the floor of the tub. We wanted a shower so we replaced the window with a new vinyl window and added tile to 64" over existing wall. Water is now leaking, down the wall into the lower level. It doesn't leak all the time, but we are now ripping out all the tile around the tub/shower surround and sheetrock down to the studs to see what extent the damage is and will replace any rotted wood etc. before building it back up. We want to do it properly. How should we go about this, and how do we seal around the window etc. to ensure this won't happen again?
I have read lots of blogs about the window, but do not want to remove it. Are there vinyl surrounds with window cut outs or should we just re-tile it? Any suggestions and/or guidance would be much appreciated.
Diane Quann is offline   Reply With Quote
Old 04-21-2014, 06:26 PM   #2
Rewards Points: 12,884
We can not see what your seeing without a picture.
As you have read it's never a great idea to have a window in a shower, now your seeing why.
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
Water Heater leaking at the nipples camerondon Plumbing 9 07-26-2012 08:56 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 10:30 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
