Want To Tile But Worried About Door Clearance - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-21-2007, 06:26 PM   #1
want to tile but worried about door clearance
I want to tile a small porch on the side of my house, but I am concerned that the door opening is only 80 inches now and tiling will cut off 1/4 to 1/2 inch at the bottom. I want to have a metal sercurity screen door installed later, so I can't just cut the bottom off the door.
My question is whether the new door can be installed a little higher by just altering the trim around the door. Can it be built out so that the door will be flush? I am not so concerned about it looking funny as there being structural reasons to not do this. The trim will have to be replaced anyway as it has some dry rot.
For those of you living in other parts of the county, what I am talking about is a heavy duty metal screen door that you can lock at night or when not home, so that you can leave your regular door open for ventilation. I don't want to have to have a custom shorter door made, too expensive.
Thanks for your help!
AZ_Kaylee is offline   Reply With Quote
Old 09-21-2007, 09:45 PM   #2
Most screen doors have a adjustable sweep, even security ones. Does yours?
jiggyjack is offline   Reply With Quote
Old 09-21-2007, 10:51 PM   #3
haven't bought the door yet
I have not bought the security door yet, but have looked at them at both Lowe's and HD. I do not remember there being anything like that, just the steel frame. But I could call about it. Thanks for the suggestion.
Old 09-26-2007, 05:57 PM   #4
Rewards Points: 5,336
You need to know how the side porch is constructed before you can do the job. How were you planning this job? You might findout that this job requires more structure then can fit the space.
Ron
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
