Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-24-2011, 09:19 AM   #1
Want to remove ceiling in cottage to create vault look.
Have a small cottage that I am renovating. I removed the drywall ceiling and like the vaulted look. I saw the same look in a Room Crashers episode. I was going to reinforce the roof with 2x6x8 at the peak. I was told by someone I can't remove the 2x4 ceiling joists because they give structural support to the house. He said removing them would change how the roof weight is distributed.
Is that correct?
Worst case senecio I could move the 2x4 together 36" apart and creat a beam look?
Greg pa is offline   Reply With Quote
Old 11-24-2011, 12:42 PM   #2
Super Moderator
Post a picture or a drawing-----your idea of cross beams would be the simplest---
A working ridge beam requires roof work---
Insulation may require adding to the roof rafters in order to get the 11 inches of space for fiberglass insulation.
Old 11-24-2011, 02:57 PM   #3
This is a seasonal place so no insulation. Here is what I want to do:
Want to remove ceiling in cottage to create vault look.-image-2526298198.jpg   Want to remove ceiling in cottage to create vault look.-image-898351543.jpg
Old 11-24-2011, 03:02 PM   #4
Super Moderator
I believe that would work---There are a couple of three or four engineers /designers here that will know for sure---Mike--
Old 11-24-2011, 09:59 PM   #5
Moderator
Your two diagrams are for two different applications. To move the rafter ties up yet staying in the bottom 1/3 of the total rise is do-able. The rafters need to be sized for the added drywall application as do the fastening to the rafters. A new sized ridge beam with proper fastening and bearing to the earth is also do-able. Both would require a building permit to meet minimum safety guild-lines.
Gary
Clothes taking longer to dry?
Old 11-29-2011, 02:07 PM   #6
Is your existing roof construction trusses? Might be easier to just take it all down and build a proper cathedral ceiling.
What to do with this old ceiling? mudworm Building & Construction 4 07-17-2011 05:54 PM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 04:47 PM
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 10:42 PM
Best way to remove "stucco" finish for ceiling HomeRepairNoob Painting 7 07-03-2008 09:47 PM
How do I remove stucco from a ceiling painted with oil paint labnotes Painting 4 01-09-2007 11:26 AM
