Wallpaper Removal [Forgot Where I Posted Before] - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-26-2007, 01:07 PM   #1
Rewards Points: 150
Attached I hope is a picture of a small area that I removed the wallpaper from in a bathroom.
It appears that maybe some of the drywall paper is coming off with the wall paper, but none of the gypsum is showing.
Is it safe to continue to remove the wall paper or would I be better off to stop now, prime it and apply texture over it.
shapeshifter is offline   Reply With Quote
Old 11-26-2007, 03:17 PM   #2
Rewards Points: 150
How did you remove it so far? Just rip the loose stuff or did your try paper remover and steamer? I removed 3 layer of waper (first layer installed circa 1967) using a combination of remover and steamer. Amazingly, it all came off with a bit of elbow grease, with minimal scarring to the drywall. A little bit of skim-coating and the wall was ready to paint.
Good luck, but I think you should try to remove it....
slakker is offline   Reply With Quote
Old 11-26-2007, 05:57 PM   #3
Rewards Points: 150
So far I used one of those wallpaper alligators, a putty knife, and fabric softener mixed half-and-half with hot water. It has come off pretty easy. There is only one layer of wallpaper. I was concerned about damaging the drywall.
Old 11-26-2007, 07:08 PM   #4
Rewards Points: 150
The fabric softner is good substitute, but I would still get a good quality remover from a specialty paint store like Ben Moore or the like...
I also bought a steamer... it cost me only $50 from HD and it worked like a charm...
I'd be carefull with the aligators, they do nick up the wall a bit....
Old 01-24-2008, 01:58 PM   #5
dekor8r2008's Avatar
Diff
I used a product called Diff when I had to remove a couple of layers. I was pretty nervous about pulling it down since it was put up poorly in the first place. It worked great and I had no problems at all. Hope that helps!
dekor8r2008 is offline   Reply With Quote
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
Fixing a wallpaper removal mishap applesusan Painting 3 07-26-2006 09:02 PM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 06:41 PM
