#1 |
Wall tile to baseboard transition?
HI,
There are limited options on how I can handle this transition. Is there an industry standard way to go about this? Or perhaps a more aesthetically pleasing design? As you can see there is only about a 1/4" of wall from the bullnose tile to the corner. Not sure that just cutting the baseboard at the tile is attractive, it looks like it is (unplanned.) (pic 1) Cutting the baseboard flush with the wall the tile is on might be an option, but is that really acceptable? (pic 2) Maybe a slight bevel to transition the baseboard to the tile would be OK? A little extra sanding to get it smooth to paint?(see insert pic 3.) Perhaps Just putting baseboard to the inside corner and eliminating it on the side wall alltogether? (Except that is the corner behind the john.)(pic 3) Any Other Ideas? Hopefully the pics are in the correct order. |
#2 |
MarginallyQualified
vinyl cove base
#3 |
Disabled wood vet
That inside corner should be coped, not mitered.
Go all the way to the shower, sanding the base down until it conforms to the shower. Or return the base into the wall at that last corner. Sent from a Samsung Galaxy S2 Last edited by titanoman; 01-09-2012 at 06:01 PM. |
#4 |
Love for Construction
Start over, because you used MDF, that isn't going to last in a wet location. If it were me I would have wrapped the tile around to an inside corner.
-luke- |
#5 | |
Disabled wood vet
Wall tile to baseboard transition?Quote:
Edit: As I look at it again, you might be right. Sent from a Samsung Galaxy S2 |
#6 |
Retired carpenter
Option number two (cut in line), slightly rounding or beveling the edge.
#7 | |
Disabled wood vet
#8 |
Sorry, I am a little confused, so I numbered the sketches.
Thanks to that, I have learned how to cope.... (no pun intended.) However, the tile follows the tub line and was placed as desired. Do not want to put the baseboard over it. Not an option... but thanks. Last edited by wraiththe; 01-10-2012 at 11:25 AM. |
#9 | |
Disabled wood vet
You know what I meant about returning the base to the wall at that last corner (the other option), don't you? It is kind of a bad situation, but after paint and caulking it could look fine, and not stand out as being wrong. One more option is to belt sand a piece of base to go over the tile (I know you said you didn't want to run base over the tile). http://www.imgur.com/HTAPx.jpg Sent from a Samsung Galaxy S2 Last edited by titanoman; 01-10-2012 at 12:02 PM. |
| The Following User Says Thank You to titanoman For This Useful Post: | wraiththe (01-10-2012) |
#10 |
*#%**FW*#%***#$^&!!!!
Learned to Cope. Put the base board in with carved small piece next to tile using only a table saw and a dremel tool. Put the toilet in and the GD seal between the tank and bowl leaked. Lowes does not carry the replacement of course. |
#11 |
Super Moderator
That's rare!
What brand of toilet---Often,if you explain the problem they will let you pull parts off a new unit-- Or--buy another--scalp the parts--and return the unit for a refund.
New members: Adding your location to your profile helps in many ways.--M-- |
#12 | |
Disabled wood vet
In remodeling bathrooms seem to cause more headaches than anywhere else. Sent from a Samsung Galaxy S2 |
| Display Modes | |
| Drain tile questions for retaining wall installation. | Tmaxx1 | Landscaping & Lawn Care | 11 | 06-10-2011 12:17 PM |
| grout vs caulk spin-off... another tile wall question | diy'er on LI | Tiling, ceramics, marble | 3 | 11-02-2009 05:46 PM |
| Tile Baseboard on outside of plastic shower pan at linoleum joint? | GaryS | Tiling, ceramics, marble | 2 | 07-26-2009 01:39 PM |
| Bathroom wall tile | Ricksweares | Flooring | 10 | 02-26-2008 04:16 PM |
| Raising Doorway Height (load bearing?) | treefrog | Building & Construction | 6 | 02-25-2008 10:11 PM |
