Wall Mural Replacement - Opinions ??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 03:21 PM   #1
Wall Mural replacement - opinions ???
This might be a better place to ask. I just ripped out an old mural to replace with a new one. Are the 2 beams sufficient to simply add new sheetrock or do I have to brace the moulding pieces on each side somehow as well. THANKS
Wall Mural replacement - opinions ???-img_1113.jpg   Wall Mural replacement - opinions ???-img_1114.jpg
zman22 is offline   Reply With Quote
Old 07-26-2012, 04:15 PM   #2
DIY staff
Rewards Points: 7,174
You should be okay with the studs ---the short cantilever will work with normal drywall---
I see no easy way to add a nailing piece behind the tile work---
Pack any gaps with easy sand 20 minute (powdered drywall compound.)
zman22 (07-26-2012)
Old 07-26-2012, 04:21 PM   #3
Run a couple horizontally top and bottom between the studs to give you a nice nailing ( or screwing) edge. You should be able to get a 2x into the left side and screw into it thru the existing stud but it looks like theres a pipe in the way on the right. Maybe you can pack it out with a strip of 1x?
This will all serve to make replacing it in the future easier.
Evstarr is offline   Reply With Quote
The Following 2 Users Say Thank You to Evstarr For This Useful Post:
oh'mike (07-26-2012), zman22 (07-26-2012)
Old 07-26-2012, 04:31 PM   #4
DIY staff
I assume that is not a wet area----if it is inside a shower---come back----
Old 07-26-2012, 06:19 PM   #5
Kitchen area
Thanks for the responses. This is in a kitchen (dry area) but that is a shower you see on the other side. Shouldnt get the kitchen wall wet or moist I believe. Also the pipes are not really in the way.
One thought is to notch out the studs you see in the middle of each with my Rockwell and slip a 1x4 accross to the left and right behind the sheetrock / picture frame. Maybe even a dab of PL to adhere the 1x4 to the sheetrock. That should be enough support right ?
Old 07-26-2012, 06:24 PM   #6
Easy Sand
Where do I get easy sand ? Thanks
Old 07-26-2012, 06:29 PM   #7
DIY staff
All stores have it --usg product--white paper bag---will have 5-20-45 or 90--on it--those numbers are the setting time---forget 5 minute--it gets hard while I mix it!
20 is good for small patches---often it is mistakenly called 'Durabond'--which comes in a brown bag and is used for exterior work,mostly--and is hard as concrete when it sets---
Old 07-27-2012, 08:01 PM   #8
final result....
So I notched both studs in the middle which allowed me to slip in the 2x4s in the corners and then run a 1X4 accross. Lucky for me these are 2x6 beams. All I have left is to add a 2x4 top and bottom.
Time to tile again.
Old 07-27-2012, 08:03 PM   #9
The result pics.
Almost forgot the pics
Old 07-27-2012, 08:31 PM   #10
Rewards Points: 2,210
Will not the easy sand just crack? Asking as I have never used the product
mae-ling is offline   Reply With Quote
Old 07-27-2012, 09:05 PM   #11
easy sand crack ?
I hope not. I have never used easy sand either. Worse case I will use the matching caulk color of my Tec grout. Only the edges could crack but the caulk would definitely help. However, I am going to use grout first and see what happens.
Old 07-31-2012, 12:48 AM   #12
Rewards Points: 4,796
That was completely unnecessary. Across the top and bottom are necessary, across the middle is superfluous.
jeffnc is offline   Reply With Quote
Retaining wall replacement mcjin1 Landscaping & Lawn Care 2 04-26-2012 01:45 PM
Replacement tiling in bathroom on damaged walls JeanB Tiling, ceramics, marble 0 04-20-2012 09:52 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
