Wainscoting Picture Frame Style: Mounting, Caulking, And Expansion Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 09:49 PM   #1
randlefactor's Avatar
Rewards Points: 39
Hello,
I've got my dining room primed and ready for paint (wallpaper removed) and my wife has her head set on picture frame style wainscoting (see image of a sample finished room). The idea is to make rectangles out of trim and nail them to the drywall, then paint everything.
1. How should I bond the corners of these frames? One How To suggested hot glue. Nailing is better, right?
2. How should I attach the frames to the wall? Finishing nails into drywall?
3. Should I caulk around the frames after mounting them? We get a lot of shrinkage in the winter here so I'm worried about cracks appearing.
4. Does it matter if I do this install during winter. Indoor humidity is about 35% right now.
Thanks!
Wainscoting picture frame style: mounting, caulking, and expansion question-image-1465624793.jpg   Wainscoting picture frame style: mounting, caulking, and expansion question-image-607346184.jpg
randlefactor is offline   Reply With Quote
Old 01-08-2013, 10:33 PM   #2
Rewards Points: 13,228
Nailing it into just the drywalls not going to stay in place. Need to hit the studs.
I use some of this plus finish nails.
http://www.loctiteproducts.com/p/12/...n-Adhesive.htm
Trim almost always will need some caulking because walls are never flat.
I use Tite bond II to glue the outside corners so they stay tight.
I paint the wall, and preprime and paint two cots on all the trim before even cutting so I only have to do a small amount of touch up painting.
randlefactor (01-09-2013)
Old 01-08-2013, 11:02 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
you also need caulking where wood touches drywall because there will be a thin black line anyway. the paint wont fill that hairline crack, if any shrinking occurs the paint will crack anyway.. the caulking eliminates that
you dont HAVE to nail to studs but it helps.. if thers nothing to nail to, glue and cross nailing will work also
woodworkbykirk is online now   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
oh'mike (01-16-2013), randlefactor (01-09-2013)
Old 01-08-2013, 11:36 PM   #4
i used the loctite that joe mentioned on the back of the molding(just a small bead, great stuff. i used wood glue on the corners and shot a couple of 18 guage brads in each piece. caulked everything after the glue was dry and painted. still looks great.
Wainscoting picture frame style: mounting, caulking, and expansion question-p1050823.jpg
The Following User Says Thank You to DannyT For This Useful Post:
Old 01-12-2013, 09:32 PM   #5
Rewards Points: 39
Here's the first frame. 15 more to go plus touch up and caulking.
Wainscoting picture frame style: mounting, caulking, and expansion question-image-2613796922.jpg
Old 01-12-2013, 11:24 PM   #6
the hardest part for me was getting the layout uniform. looks like you got a handle on it. looking good.
randlefactor (01-15-2013)
Old 01-15-2013, 10:38 PM   #7
AHH, SPANS!!!
Rewards Points: 1,166
dividing up where they fit evenly spaced onto the wall and not hit receptacles is the trickiest part no doubt
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Old 01-15-2013, 11:38 PM   #8
Rewards Points: 39
You guys are right about the measurements being most important to get it all uniform and avoid outlets. Here's the finished room. So glad I'm finally done!! Thanks for everyone's tips!
Wainscoting picture frame style: mounting, caulking, and expansion question-image-3103482506.jpg   Wainscoting picture frame style: mounting, caulking, and expansion question-image-3469570172.jpg   Wainscoting picture frame style: mounting, caulking, and expansion question-image-3088242216.jpg
Old 01-15-2013, 11:54 PM   #9
747
registered
747's Avatar
Rewards Points: 534
Looks great. I also like the color of the walls above the white.
747 is offline   Reply With Quote
The Following 2 Users Say Thank You to 747 For This Useful Post:
oh'mike (01-16-2013), randlefactor (01-15-2013)
Old 01-16-2013, 10:37 AM   #10
great job
