Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-01-2012, 07:52 AM   #1
mnsinc's Avatar
Lightbulb
Wainscoting
Im installin gthe PVC type wainscoting and there like 36 X12. Whats the best way to attach these to the wall? Can I use a pvc adheisive and nails ,Any TIPS WILL BE VERY HELPFUL.
THANK YOU ALL IN ADVANCE mnsinc
mnsinc is offline   Reply With Quote
Old 12-01-2012, 09:24 AM   #2
Wainscoting
If you tryed using PVC cement it will get on the face of the panels and melt it.
There should be a sticker on the panels of go on the companys website to find out what they advise to attach them.
The T&G should not have any adhesive on it.
This is what I have used in the past.
http://www.loctiteproducts.com/p/12/...n-Adhesive.htm
Then I went over the panel with a hand floor roller to spread out the adhesive.
http://www.bing.com/images/search?q=...B223DC&first=1
Your rolling pin would also work.
Unless you install this over 1 X 4's sitting horizontal nailing it will do little good. Count on the base board and chair railing to hold it in place once it's attached.
Do not try and set it directly on the floor leave about 1/2, floors are never perfectly flat or level.
I'd use a chaulk line where you want it to rest at the top.
I also strat in the middle of the wall and work my way out, that way the end cuts are even.
Old 12-01-2012, 11:04 AM   #3
AHH, SPANS!!!
Wainscoting
I'd use a construction adhesive on the wall behind the panels and tack nail the panels till the glue sets.
hand drive is offline   Reply With Quote
Old 12-01-2012, 01:14 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Wainscoting
i use a fair amount of pvc trim.. especially azek for decks. occasionally we use it for trimming out windows inside of showers.. weve found using white polybutyl window and siding caulking works best as an adhesive any ooze out will be the same color as the trim and it holds it in place.
if your installing it for on the outside of the house do not use regular galvanized gun nails they will bleed as they rust.. stainless steel fasteners are the only way to go with it.. 4 years ago we found out the hardway on a job that took $40,000 in pvc trim material alone not including the cost to install it..this job was right on the water and 6 months later we had to go back and scrub down all the trim and fill the holes with epoxy filler
woodworkbykirk is online now   Reply With Quote
Wainscoting and trim.....same sheen? asbury park Painting 11 02-25-2012 09:07 AM
How to end wainscoting? Smitty31 Windows and Doors 3 02-21-2012 10:54 PM
Wainscoting and crown moulding with unlevel floors BobSmitt Carpentry 4 08-23-2011 11:59 AM
Wainscoting? kcrossley2 Carpentry 11 10-24-2008 07:27 PM
Wainscoting? kcrossley2 Carpentry 2 09-13-2007 10:22 PM
