-   -   Wainscot molding issues (http://www.diychatroom.com/f15/wainscot-molding-issues-16254/)
cmdrico7812 01-27-2008 09:30 PM
I am in the process of remodeling out kitchen and I am installing wainscoting in our breakfast nook area. The wainscot comes in sheets 48" x 32" x 3/8" which I got at Lowes. Today I went to Lowes and Home Depot looking for molding to cap the top of the wainscot after it is attached to the wall (typically called a chair rail). I found a chair rail piece and a thin cap piece of molding that has a cut out in the back designed to fit on top of the wainscot. The problem is that the cut out on the back of the molding is only 1/4" deep so that it won't cover the top of my wainscot completely. They only had two pieces of molding with a cut out on the back for wainscot and they both were only 1/4" deep. Has anyone else every run into a problem like this? I bought the waiscot at Lowes thinking they would have all of the pieces that go along with installing wainscot. Where can I get molding that will fit my wainscot? Thanks in advance for your help.
Eric
AtlanticWBConst. 01-28-2008 04:53 AM
Try an actual Lumber supply company that focuses on selling to builders and carpenters, as well as Home owners. They will have a much wider selection of stock.
Additionally, you can easily take ANY kind of molding that you like, and mill out a 3/8" kerf (cut) into the bottom of it with a table saw, and turn it into a wainscotting chair rail.
Handyman50 02-01-2008 12:54 PM
I had a problem similar to yours. I purchased standard casing and had a cabinet shop make the notch for the wainscot. It worked great. It didn't cost me much more than the pre-notched molding.
