Vinyl Window Without Nail Flange??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 07:22 PM   #1
vinyl window without nail flange???
I ordered a vinyl window to replace the 102"x65" front living room window.
I measured the old window outside to outside & requested a new construction window, but a replacement showed up. The business said they would contact the manufactor (Alliance ) get a new contstruction flange for it.
Does that sound possible to get??
rb69 is offline   Reply With Quote
Old 08-24-2010, 08:25 PM   #2
Rewards Points: 150
Does the contract/receipt specify new construction? If so I'm demand a replacement. I don't know much about windows, but the ones I installed had a flange that was built in, not able to be added on later.
johnnyboy is offline   Reply With Quote
Old 08-24-2010, 09:35 PM   #3
When I ordered it I did specify new construction. I asked him after he said that he could get the nail flange that would take care of it, if this doesn't work can I return it? It was a custom window & paid B4 ordering & he in so many words said it couldn't be returned
Old 08-25-2010, 01:40 AM   #4
The number one weapon that window and door companies use against customers is "the contract". Anytime a customer of ours (we sub for large companies) has an issue, the first thing the companies will say is that you signed on it so tough luck. In your case it's your weapon. Fire back with it. You signed for a new construction window with a flange. If it's a PVC or metal clad window, the flange should be part of the window. Not a separate piece attached later. That said, I am in Canada. I've been installing windows and doors for 12 years now for the largest window manufacturers in the country. I've never put in a window with a flange that wasn't a part of the window. But I have ripped a lot out. Not sure how manufacturers do it outside of Canada.
FehrboysInc is offline   Reply With Quote
Old 08-25-2010, 06:26 AM   #5
thanks. I check w/ maker of the window.
Last minute Tips for Window Replacement? gmhammes Remodeling 20 08-17-2010 09:09 AM
Oak casing to a vinyl jamb extension on a new window? Dustball Carpentry 13 04-14-2010 12:06 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
