Vinyl Tiles In Shower Possible? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 11:13 PM   #1
Vinyl Tiles in shower possible?
Hi everyone, I am planning on renovating my bathroom really soon and was wondering if I could use the groutable vinyl tiles in the shower?
I have read to not use them on walls, but was told by the people at HD to use them...
Heres what my plan was going to be...
- Demo walls in shower down to studs
- Drywall followed by liquid waterproofing (Or do I have to use concrete board?)
- Vinyl tile on walls (no need for floor cause of tub and no need for ceiling)
- Grout
- Silicone Caulk around edges.
Is this possible? Or am I way out on my plan?
Any help would be greatly appreciated thanks alot!
JerLinde is offline   Reply With Quote
Old 03-12-2011, 05:18 AM   #2
DIY staff
Rewards Points: 7,174
You are way off-----Drywall of any kind has not been allowed in a wet area for many years in the U.S. and Canada.
Vinyl tiles are no good for that ---use ceramic.
You are going to put a lot of work into that project---don't spoil it by using the wrong materials.
Read through the tiling section---there is a lot of good information there,---Mike--
Old 03-12-2011, 08:21 AM   #3
Rewards Points: 5,336
- Grout
This plan will not work at any level.
No drywall.
No plastic tiles
No advice from bigbox store employees.
Use the concrete board and ceramic, porcelain or stone tiles over the waterproofing.
Ron
Old 03-12-2011, 09:51 AM   #4
Thanks alot for the help guys, I had a feeling I was going wrong.
So here is my new plan, let me know what you think.
- Concrete board followed by liquid waterproofing, probably RedGard
- Probably porcelain or Ceramic tile on walls (no need for floor cause of tub and no need for ceiling)
- Grout
- Sealant over tiles and grout.
How does this look? Am I missing anything? And also can I use drywall screws on concrete board? Or do I have to get different screws.
Thanks again!
Old 03-12-2011, 10:14 AM   #5
- Grout
Thanks again!
Sealing the tile isn't necessary as the surface will not absorb water. Stone should be sealed on a regular basis along with the grout.
Ron
Old 03-16-2011, 09:52 AM   #6
Great advice here.
pjordan4477 is offline   Reply With Quote
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Glass tiles on Shower floors? judy9876 Building & Construction 1 03-30-2009 05:55 AM
Traffic Master Peel off Vinyl Tiles fishtayl Flooring 4 11-02-2007 11:56 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
