Vinyl Soffit Under Porch Roof - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-24-2010, 01:02 PM   #1
vinyl soffit under porch roof
I have an l-shaped porch. How do I install vinyl soffit? When I try to mitter it it does not seem to fit properly.
contactrock is offline   Reply With Quote
Old 11-24-2010, 01:07 PM   #2
My porch is shaped like an " L ". I tried mittering the soffits, but they do not seem to fit properly. Cn anyone help?
Old 11-24-2010, 01:54 PM   #3
kwikfishron's Avatar
Rewards Points: 998
Doesn’t seem to fit what properly, in the channel, lines don‘t line up, what?
kwikfishron is offline   Reply With Quote
Old 11-24-2010, 02:38 PM   #4
Yes...the first one will line up perfect, but the next one won't. As you well know the soffit is divided in 2 sections. The sections do not line up with the mitered one.
Old 11-24-2010, 03:00 PM   #5
Old 11-24-2010, 03:06 PM   #6
Rewards Points: 998
If your two sections of porch are different widths and your double channel runs from the outside corner on the house to the outside corner of the porch you will not be at 45 degrees and your angles won’t line up
The Following User Says Thank You to kwikfishron For This Useful Post:
contactrock (11-24-2010)
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 10:21 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
porch post vinyl or metal to stop painting? hobbyguy2002 Building & Construction 2 01-28-2008 03:37 PM
