Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-16-2013, 06:23 PM   #16
Vinyl Siding Over Wood, Double Vapor Barriers, and Windows..oh my
Looks normal in that picture, go back and look at the first picture of the house you posted, see how that over hang looks like it's at an angle.
Most have just been the angle the picture was taken.
Old 02-16-2013, 06:51 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
simply cutting back the shingles to create an overhang does a sloppy job. its much stronger by resheathing the roof and creating the overhang that way
woodworkbykirk is offline   Reply With Quote
Old 02-16-2013, 07:10 PM   #18
The best way looks like this.
http://www.bing.com/images/search?q=...electedIndex=8
Old 02-16-2013, 07:14 PM   #19
Sorry about that bad first picture. Anyway, thamks for the advice, but the link you posted won't work for me. So if I went with no foam insulation, would Gary's idea with the stucco wrap work?
chronojosh is offline   Reply With Quote
Old 02-16-2013, 07:18 PM   #20
I'd just wrap it with Tyvek and side it.
But first I would remove the gutters, remove the plywood covering the soffits and use vented vinyl soffit, then wrap the fashias with coil stock.
Then there would be no painting and plenty of ventalation.
All the rim gets done first before the siding goes up.
chronojosh (02-16-2013)
Old 02-16-2013, 07:51 PM   #21
Just because im new to stuff like this, what do you mean by the rim?
Old 02-16-2013, 08:16 PM   #22
One of my fingers fell off so I made a booboo.
Should have been trim not rim.
Old 02-16-2013, 08:35 PM   #23
Ha is that guy making fun of my spelling or is it spam?
Old 02-16-2013, 08:57 PM   #24
Ah. No problem. Thanks for the help
Old 02-16-2013, 09:01 PM   #25
I hope you do not plan on trying to do any of this work this time of year up there.
The siding would shatter like glass when you go to cut it.
My son lives up in CT.
Old 02-16-2013, 09:16 PM   #26
Haha no, not doing this until spring. Do you think the stucco wrap would be better than just tyvek? Also, how would I tie it into the windows to prevent leaks?
Worthwhile to replace old wood frame basement windows with new vinyl windows? Cost? TomServo Windows and Doors 5 10-25-2012 08:10 AM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
New windows and new vinyl siding Fisher252 Building & Construction 11 05-09-2011 12:17 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
