Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-04-2012, 07:02 AM   #1
workshopaholic's Avatar
Vinyl siding over concrete block
I'd like to finish an old painted concrete block storage building to match the new vinyl-sided main house.
I've found conflicting information on how to handle this. I've been told to use 1x3 furring only. Another source says that I must put 3/4" foam insulation between the furring strips or else the vinyl will become wavy. I've also heard that I need a minimum of 2x furring, again with and without insulation. It's also been suggested to put 1x furring and cover with 1/2" OSB (although I'd be worried about the OSB getting wet from rain splashing up off the ground).
I've installed plenty of vinyl siding, but always on wood-framed walls with plywood sheathing. I just can't get a handle on how to do it over block.
I'm located in northeast Florida, if that matters.
workshopaholic is offline   Reply With Quote
Old 05-04-2012, 10:33 AM   #2
is the building heated or not?
How close to the ground will the vinyl go?
mae-ling is offline   Reply With Quote
Old 05-04-2012, 11:25 AM   #3
Not heated, but the interior already has a drywall with foam underneath. The building stays quite cool/warm already, so more foam just for insulation's sake wouldn't be needed, I think.
Maybe 2-3 inches? I was going to leave a gap for trimming with a weedeater. I could see leaving as much as four inches and still look good.
Old 05-04-2012, 11:29 AM   #4
Own my own house I used strips of Advantec 3/4 subflooring, reason being is I had it on hard, it's not that expencive, far more water resestant then plywood or OSB.
I used 8" wide strips at the bottom, 6" wide in the corners, around windows and doors and the top, and 3" wide for the field. You need to do all the outside pieces and around the doors and windows first, then the field.
It also would be best to cover all your expost wood on the soffits with vinyl soffit and cover the fashias with coil stock before any siding goes on.
My slab was pored way to low so I used strips of coil stock bent 90 deg. along the bottom edge to help keeping water off the bottom edge, then I used 1 X 6 vinyl lumber along the bottom. That way the weed wacker will not hit the siding. It's best to run the vinyl lumber all the way to the outside corners so the vinyl corner sit on top of the 1 X 6 vinyl lumber.
On top Of that I put Z moulding, then J moulding.
Depending on how your windows and doors are trimmed now you may have to build out all the trim, and cover with PVC coil stock before siding.
I installed 3/4 foam to the walls between the strips but for a garage if you spaced the stips every 16" you should be able to get away without it.
We tryed using a ram set but my block was so poopy we had to use Tap Cons instead.
We used 1-1/4 roofing nails to hang the siding and they worked fine, Siding is hung not attached tight to the wall.
As soon as we finished people started stopping by that I had never met before and saying how much better it looked.
Old 05-04-2012, 11:03 PM   #5
I've watched guys furring out clay tile block buildings with 1x material and xps. It makes sense to me.
I think I am in a high wind area. At least it seems that way to me whenever I'm installing siding or fascia or soffit. I always nail vinyl every 8" when it's on osb. This would add some more strapping.
cleveman is offline   Reply With Quote
Old 05-04-2012, 11:31 PM   #6
You would attach furring strips to the block wall with sleeve anchors or tap cons then apply the vinyle siding.
epson is offline   Reply With Quote
Old 05-05-2012, 07:52 AM   #7
Moderator
kwikfishron's Avatar
I'd strap the wall with 3/4" "treated" plywood with 3/4" foam in between the strapping.
Use "ring shank" roofing nails for the siding.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 05-05-2012, 09:08 AM   #8
KemoSabe
loneframer's Avatar
I firred out with treated 2x4 because any wood in direct contact with masonry should be treated.
Covered with OSB, #30 felt paper, then vinyl siding and PVC trim.
Vinyl siding over concrete block-009-copy-3-.jpg   Vinyl siding over concrete block-011-copy.jpg   Vinyl siding over concrete block-003-copy-2-.jpg   Vinyl siding over concrete block-010.jpg   Vinyl siding over concrete block-021.jpg
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 05-05-2012, 09:12 AM   #9
KemoSabe
loneframer's Avatar
Finished
Old 06-01-2012, 04:00 PM   #10
I did this to a 4 stall garage about 8 years ago. All I did was use a 3/16 x 1 1/4 tapcon where a nail would be. Be sure to hit the joints,not block. Pre-drill holes and do not screw tight to wall. Have had No problems with waves or moisture.
antlerdancer is offline   Reply With Quote
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 11:28 AM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 10:32 PM
New Vinyl Siding Went From $43k to $15k In A Few Days nycgto Off Topic 12 07-27-2010 12:46 AM
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 07:27 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
