Vinyl Siding An Old Garage? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-20-2008, 07:48 PM   #1
Rewards Points: 14
Question
Vinyl siding an old garage?
I have a rental property with an old wood sided garage that is in sound condition. I wanting to apply vinyl siding but I'm not sure if I should wrap or foam the garage before siding? The garage is not heated or insulated. This is in north central Wi. Thanks.
wibass is offline   Reply With Quote
Old 03-20-2008, 08:05 PM   #2
Res Ipsa Loquitur
I don't know about using foam but I am doing the same thing at a New Jersey shore home. I am just wrapping with roofing felt under the vinyl to keep minor drafts out between the sheathing boards. Without heat I don't see much of a point in spending/doing more than that.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-20-2008, 10:26 PM   #3
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
If your going over the existing wood siding the proper way to do it is with at least 3/8" foam board.
This will give you a even plane to which to nail the new siding, keeping it from following the recessed areas of the beveled face of the old stuff.
Do not use black tar paper under it.
oldfrt is offline   Reply With Quote
Old 03-21-2008, 04:23 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated, there are two purposes for using the the foam (fan-fold).
1.) The slightly increased R-value (3/8"= +1.46 to + 3.44)
2.) It creates a flat surface over the existing siding, in order to properly apply/lay/install your vinyl panels over (so that these lay flat).
- Build Well -
Old 03-26-2008, 07:27 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Use the fan-fold insulation. The r-value is irrelevant for your app., but as mentioned, it will give you a flat surface to work with.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
