Vinyl Siding Installation Question (with Pictures) - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 07:28 PM   #1
Rewards Points: 150
Vinyl siding installation question (with pictures)
Hello,
I want to install some vinyl siding on a 'hut' I built. Issue at hand is the starter strip, as my base has a straight and angled part to it.
Could I simply use a piece of starter on the bottom straight part and then use a J trim for the upward angle part by the stairs? Id have to cut the vinyl to an angle, and maybe add another furring strip to help secure it (the upward jtrim part), but Im hoping that would work.
Heres a pic of the straight starter, just picture the jtrim on the upward angle...
I asked a neighbor, and he suggested that I run the starter strip further in, and add a spacer to anchor it to the cement wall. Im not as keen on this method..
What do you guys/gals think?
Thanks.
sbmfj is offline   Reply With Quote
Old 08-06-2012, 07:33 PM   #2
Rewards Points: 528
First method is the one I would use.
Totally up to you.
framer52 is offline   Reply With Quote
Old 08-06-2012, 07:37 PM   #3
Rewards Points: 150
thanks.
Can I sure a jtrim for a finish at the top of a building? Its another angle.
Merci.
James
Any other siding tips you may want to share with me? Ill take em all.
Old 08-06-2012, 07:39 PM   #4
Rewards Points: 150
just realized I caught a bee in the picture..so random.
Old 08-06-2012, 08:05 PM   #5
Rewards Points: 14,026
Why the batten strips on the wall?
I would wrap the fashia, soffit and any other trim with coil stock with coil stock before the siding goes on.
Any windows or doors will need a piece of Z moulding on the top of them before the J moulding goes up..
Old 08-06-2012, 08:25 PM   #6
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
http://www.vinylsiding.org/INSTALLAT...nual/index.asp
oldfrt is offline   Reply With Quote
Old 08-07-2012, 09:54 AM   #7
Rewards Points: 2,212
For looks I would use J all across the bottom and top.
Drill some weep holes in it.
mae-ling is offline   Reply With Quote
Old 08-08-2012, 07:54 AM   #8
Rewards Points: 150
thanks for the tips guys. Im going to finish the flashing beforehand, and then begin the siding. I think ill go for my first option, and hope for the best.
Old 08-08-2012, 07:44 PM   #9
Rewards Points: 150
Hi again,
I want to install some soffit under the little roof overhang right above the door. I imagine for this part, it would be best to install the siding up to top, and then install the soffit? Or should I install soffit before hand, and then install a jtrim over that and have the siding run up into that?
Hard to explain..heres a photo
or
where a ] is a piece of siding and the --- is the soffit. First one is with soffit installed first, and siding with jtrim but up to it. Second option has the siding installed first, no jtrim at top, and then soffit butts up to the, and Id use an aluminum jtrim for the soffit?
Old 08-08-2012, 08:15 PM   #10
Soffit is nailed up first, then fashia, all the trim then the siding
I do the tops of my walls a little differant. I use 1/2 J moulding, then install a piece of utility trim up inside of it upside down.
When you get to the last piece you mark and cut it to width, and punch it with a pair of snap loc plyers, http://malcoproducts.com/product/roo...lock-punches-a
Now it will snap in place and never fall out.
Old 08-08-2012, 09:09 PM   #11
Haverhill Trade 1965
If you use the J on the angle make sure you leave room between it and the starter strip for any water that can get in, gets out at the bottom before it gets into the horizontal section of siding.
Duckweather is offline   Reply With Quote
Old 08-08-2012, 09:32 PM   #12
A simple cut out in the bottom of the J so no one sees it will work for a drain hole.
Cedar type vinyl siding installation cost? Dshow Building & Construction 4 04-22-2012 10:43 PM
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 10:11 PM
Vinyl siding installation question Branden Building & Construction 2 06-01-2010 12:17 PM
emergency vinyl siding installation question!!! diy'er on LI Building & Construction 9 08-13-2009 11:16 PM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
