Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-30-2011, 08:42 PM   #1
Mr. Handy
Vinyl Siding Getting Started Right
I will be siding my house with vinyl siding and the house has several features at different levels, such as a deck, porch etc. that cause me to struggle how to determine where the starter strip should begin. To make the siding match as I work upward is the challenge. Do I measure from the soffit down? Do i use a builders level or what should i use? This house is 2 1/2 story farmhouse.
swiederin is offline   Reply With Quote
Old 03-30-2011, 09:09 PM   #2
Moderator
kwikfishron's Avatar
I always pull numbers off the roofline (soffit) and pull a string line. All of my layout reference comes from that string.
A builders level is a fine tool in most cases, just don’t use one for siding on a crooked house.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (03-30-2011)
Old 03-30-2011, 10:50 PM   #3
Moderator
Sounds as if you may need this, also; http://www.abtco.com/kp_abtco/docs/A...tructions_.pdf
Gary
Clothes taking longer to dry?
Insurance claim for vinyl siding thru-hiker Off Topic 3 12-02-2010 03:29 PM
Vinyl siding above pitched porch roof - how to secure the bottom of the siding? joshoc Building & Construction 21 10-09-2010 01:42 PM
heat vents for vinyl siding skychief Building & Construction 3 06-11-2010 09:37 PM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 11:13 AM
vinyl siding over wood siding loyal Building & Construction 6 05-26-2009 01:17 AM
