Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-15-2010, 08:50 PM   #1
Vinyl Siding Corner Post Obstruction
I am planning a residing effort for my home. Most of my exterior is pretty straight forward for installation, except around my two from porches. The fascia on each of them bump up almost flush with the corners of my home and im not sure how to handle that regarding the installation of the OS corner post.
Im hoping someone can tell me if I just notch out the corner post where the porch fascia and roof line is or if I terminate the corner post at the porch eve, install J-channel at the edge of the fascia board then continue the corner post at the porch roofline up the remainder of the corner.
As part of this residing project i will be installing aluminum soffit and fascia to the porches if that has any impact on a recommendation.
Attached are a few pics of what Im talking about.
Vinyl Siding Corner Post Obstruction-p4150075.jpg   Vinyl Siding Corner Post Obstruction-p4150076.jpg
JDPagel is offline   Reply With Quote
Old 04-16-2010, 01:09 AM   #2
Tom Struble's Avatar
yeah that's a tuff detail sometimes,if you strip the shakes you will get the corner to be where its supposed to be,and get a ''better'' job in the process
other than that,notch the corner around the fascia and end it under the gutter
Tom Struble is offline   Reply With Quote
Old 04-16-2010, 07:11 AM   #3
Moderator
kwikfishron's Avatar
All I can add is to first do your notch in a scrap piece of corner so your dialed in when cutting the real one.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (04-16-2010)
Old 04-16-2010, 09:59 AM   #4
Thanks for the info and recommendation. I'll give it a whirl when I kick off the project in a couple weeks.
Old 04-16-2010, 01:46 PM   #5
hard to tell but it looks like that is a trim pc directly below the gutter,if it is i would pull it off
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 11:13 AM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 01:35 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
