Vinyl Sidig - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 05:58 PM   #1
ntw
vinyl sidig
I am having new vinyl siding installed the kind that has styrafoam on it already but they are not wrapping it first is that ok? I live in michigan the quote was the same as all the other ones. I have wood clapboard on it now so it will be going over it.
ntw is offline   Reply With Quote
Old 04-17-2013, 06:39 PM   #2
Rewards Points: 14,312
Why? Your going to pay at least double what reguler siding would cost and gain almost nothing in R value.
There's going to be air leaks at all the seams and every outside and inside corner.
Old 04-17-2013, 07:41 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,358
joes right,, the only real purpose of that foam is to make it more resiliant so it doesnt lose its shape
woodworkbykirk is offline   Reply With Quote
Old 04-17-2013, 07:51 PM   #4
The lady I'm living with fell for the "insulated" siding scam.
It's made 0 differance in the heating and cooling cost, and she paid three times as much a reguler siding job would have cost and it threw all the windows and door trims off because all the trim needed to be wider to fit the new siding.
She could have had .045 thick siding installed and had the same look and saved over $5000.00.
GBrackins (04-17-2013)
Old 04-17-2013, 09:27 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
and a lot of people will read Joe's post #4 and say, "wow, why didn't they tell me that before selling it to me?"
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-17-2013, 11:21 PM   #6
Registered User
Rewards Points: 526
No, it is not ok, houswrap or builders paper/equivalent is required per code minimum;
http://publicecodes.cyberregs.com/ic...9_7_par027.htm
Gary
framing for vinyl wind barrier (See photos) Carolyn252 Building & Construction 2 09-02-2011 04:50 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
