Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-14-2010, 05:10 PM   #1
WaldenL's Avatar
Vinyl meets Cement (Hardie) Siding at corners
As part of the kitchen remodel (we were just going to fix the ceiling ) we replaced a couple of windows and put in a french-door. We're now looking at replacing the siding on the back of the house since we've killed most of it in the remodel anyway. We want to replace the vinyl with something like a Hardie cementboard siding; however, residing the entire house is not in the budget right now. So, here's the question:
On an outside corner where one side of the house is vinyl and the other cement board can I just use a vinyl corner piece? IOW, the corner piece is for looks only, right? The siding is held in place w/nails across the entire run.
WaldenL is offline   Reply With Quote
Old 06-14-2010, 09:00 PM   #2
Tom Struble's Avatar
you can use vinyl accessories with cement siding,my advise would be to seal any field cut ends with a good acrylic paint before you slide it into the corner,some may say to caulk the inside pocket of the corner first I'm just not sure how effective doing this is...jmo
Tom Struble is offline   Reply With Quote
Old 06-14-2010, 09:37 PM   #3
Exterior Resources, Inc.
ExteriorRes's Avatar
You can insall a Hardie / Cedar trim board at the corner. You will need some J-channel to finsh off the vinyl siding and you will be able to but the Hardie siding to the trim board.
ExteriorRes is offline   Reply With Quote
Old 06-15-2010, 07:18 PM   #4
WaldenL's Avatar
Thx all.
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 35 09-26-2011 06:08 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
