Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-26-2012, 09:39 PM   #1
vinyl jamb extensions
We just had new windows installed in a new home construction. The contractor did not factor the strapping required for the wood siding and as a result we are an inch short in the jambs. What can we do?
mcart is offline   Reply With Quote
Old 06-26-2012, 09:43 PM   #2
Just use 1 X clear pine, or birch.
Old 06-27-2012, 06:03 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you are referring to the interior side of the windows: You can furr out the jambs using comparable material (to the planned interior wood finish trim). The width of the extension pieces should be 1/16" proud of the the actual width (depth) - difference - that you are trying to make-up.
If its going to be painted trim work, Poplar wood is the suggested wood-stock to use (as it has less knots and covers well with paint).
EXAMPLES:
http://www.andersenwindows.com/servl...%20Accessories
http://www.ezhangdoor.com/installing...xtension-jambs
Video: http://www.youtube.com/watch?v=0NZmxrqi1fc
- Build Well -
window jamb extensions too short. ideas? itsnotrequired Windows and Doors 5 04-24-2012 05:22 PM
Jamb extensions CrashBob Windows and Doors 2 04-26-2011 10:54 PM
NEWBIE QUESTION ALERT!! Jamb Extensions Evil Scotsman General Discussion 24 04-12-2011 06:30 PM
Sizing Jamb Extensions smacman Building & Construction 3 06-29-2010 01:06 PM
Oak casing to a vinyl jamb extension on a new window? Dustball Carpentry 13 04-14-2010 12:06 PM
