Vinly Siding - Matching The Color - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 10:11 AM   #1
Rewards Points: 14
Vinly Siding - Matching the color
I would like to move a window and will need to change the vinyl siding and need to find the same color for the J channel.
I have not been able to find the same color yet. It is a blue color from the 70s and I ahve not found it in stock anywhere. When I look at the web sites they want to put me in touch with a contractor. I filled out one to see where that goes. I have looked on this site to see if someone has asked this question before but no luck yet.
Anyone have experience on how to match a new siding to existing siding.
thanks
Dan.
abedj is offline   Reply With Quote
Old 02-17-2010, 10:21 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
sometimes its impossible,siding from the 70s was typically extruded today most vinyl siding is roll formed so the locks and grain pattern are different,maybe you could ''steal'' some siding from a less noticable area?
another way to match color is to paint it...yes you can paint vinyl siding
Tom Struble is offline   Reply With Quote
Old 02-17-2010, 02:24 PM   #3
Rewards Points: 14
Thanks for the information.
In the crawlspace below is a few boxes of extra siding.
I have used some of this when we converted the electric service to 200A.
I did notice it is not faded like the siding on the south facing wall.
This will be on the north facing side. Not sure if it will be as faded or not.
In any case I think I will have enough unused siding. My real color option to find the same color of J channel. I guess my options are at this point to either pain the J channel to the correct color or an accent color for this wall.
In any case, I did not think of paint but that is a good option.
Thanks again for the info.
Dan
Old 02-17-2010, 05:32 PM   #4
you can get a pce of j thats close enough from a siding supplier or just use white nobody will notice as long as the trim around the window is white also
Old 02-17-2010, 10:03 PM   #5
remodeling pro
I agree, your best shot is to steal some from a spot that is not highly visible. This may very well mean removing siding from a complete wall and residing with the closest material currently available. This will also give you the best chance for an acceptable color blend, particularly if the material you "borrow" has the same sun exposure as the wall to be repaired. Those old blues were one of the most notorious colors for fading. And as stated, the grain patterns have changed very noticeably. If you only need j channel, the color difference will not be as noticeable as with the siding.
troubleseeker is offline   Reply With Quote
Tags
color , match , matching , siding , vinyl
Matching mortar color rory535 Building & Construction 4 08-23-2009 03:12 PM
vinly siding this old house Building & Construction 3 12-01-2005 01:51 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
