Venting Range Hood - Straight Up? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 06:17 PM   #1
Thadius856's Avatar
Rewards Points: 504
Choosing a Range Hood for a Gas Range
Working on the kitchen remodel, a bit earlier than originally expected. Thought I'd have plenty of time to research range hoods, but it's turning out that we need to be start moving on it. Right meow. I'm lost in a sea of options. Three questions, hopefully easy ones:
1. Freestanding, stainless 30" range against a wall on 8' ceilings with 39" cabinets within 2" of the ceiling that will receive crown. So I'm guessing I need a wall-mounted stainless 36" wide hood approximately 30" tall. Does that seem about right?
2. I opened the drywall behind where the existing under-cabinet hood is, expecting to see it vented to the ceiling directly above and thru the attic. Not so. Venting material in the wall, but it's abandoned, and the hood was set to recirc instead. Can anybody identify this venting material?
3. I'd like the hood to butt to the ceiling, venting thru the attic and the roof if that's possible, and I'd prefer to repurpose the existing roof hole and remove the abandoned venting material. Is this feasible if I just throw two 45 elbows in there?
Tried to do my research before asking. Hope it shows.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 08-04-2012, 08:33 PM   #2
Rewards Points: 13,468
Is that PVC pipe? It's got to go and be replace with solid galvinized pipe.
It does not stick out of the roof so it's exposed, it's inserted into a roof vent.
http://www.amazon.com/Lambro-Ind-Ran.../dp/B001UFDUHO
Old 08-04-2012, 09:41 PM   #3
Rewards Points: 944
That looks like 6" oval pipe, oxidized.
I try to put an over-the-range microwave above my ranges, and vent it straight up through the cabinet above with some rectangular duct. Then I transition to 6" pipe and run ridgid up a ways into the attic, then go with flex duct and terminate near the ridge vent.
cleveman is offline   Reply With Quote
Old 08-05-2012, 05:54 AM   #4
Rewards Points: 3,130
Originally Posted by cleveman View Post
. . . run ridgid up a ways into the attic, then go with flex duct and terminate near the ridge vent.
You vent it inside the attic?? That would never pass inspection here. Even if it did, I wouldn't do it that way.
Old 08-05-2012, 12:37 PM   #5
Thadius856's Avatar
Rewards Points: 504
It's certainly not PVC. It feels white painted ceramic or metallic. Has a nice hollow thump to it. Fairly weighty. Dimpled like a golf ball IIRC. The vent cap is similarly shaped as an oval or rounded rectangle.
Seems galvy is acceptable for venting ranges. That makes things easy enough.
Do these chimney style hoods butt to the ceiling? Does my body have a picture or diagram of the connection to the venting? Thanks in advance!
Venting a microwave range Hood over the existing vertical vent out gnans Kitchen & Bath Remodeling 0 05-31-2012 09:38 PM
Problems with range hood installation. darsunt Remodeling 9 01-06-2012 04:59 PM
venting a range hood thru existing metal roof mycajah Roofing/Siding 1 03-22-2011 01:57 PM
venting range hood out ugabulldog Building & Construction 7 11-24-2010 07:32 AM
Installing a range hood NewHandyman Electrical 1 08-10-2009 09:42 AM
