Venting A Microwave Into Room? Same As Recirculating? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-11-2015, 08:21 AM   #1
Rewards Points: 14
venting a microwave into room? same as recirculating?
curious about installing an above range microwave in cabinet pictured below. having trouble finding a model that fits and has front vent recirculating. It seems a lot of them now have to stick out past the cabinet and blow out the top in front of the above cabinets because i guesss people don't like the ugly vents?
The problem below is the cabinet above is deeper and blocks the up venting that a lot have.
We purchased a microwave that fits the dimensions but it was unclear from the spec that you had to have extend beyond the cabinet 2 inches to for the recirculating vent clearance. so it appears we could only use this microwave if it was going to be using rear or top venting.
So my question is, with the vaulted ceilings in the kitchen, can I just set it up like I was roof venting, but just run duct through the upper cabinet to exhaust out into the area above the cabinets wit maybe a 45 degree elbo that points out ino the room, but is hidden in back behind trim?
bonanz is offline   Reply With Quote
Old 04-11-2015, 08:41 AM   #2
Probably would be incredibly noisy. Plus the outside vent models don't contain usually contain a charcoal filter to remove odors. They have a small grease filter but you probably want more than that for recirculation. Anyway you can vent through the roof? I cook a lot and find most of the recirculating hoods next to useless . Outside venting is more important to me than granite counters or other features .
jimn01 is offline   Reply With Quote
Old 04-11-2015, 08:54 AM   #3
Rewards Points: 14
the model we bought is meant to be both outside venting or recirculating and has an optional charcoal filter, but the recirculating portion is meant to stick out from the cabinets a few inches and vent up (which looks terrible IMO), but in our case with the deeper upper cabinet, it's blocking the upward recirculating vent.
We don't cook that much so we're okay with recirculating and don't want to make big deal of running vents out the roof etc. running a short vent out the top of the cabinet wouldn't be a big deal for a clean look with the matching set microwave with the rest of the appliances and fit nice and flush with the upper cabinet, but I'm not sure if just redirecting the vent like that would be some unsafe thing or code violation or something along those lines.
I wouldn't think so, but just checking in for more experienced opinions.
Old 04-14-2015, 12:47 AM   #4
Rewards Points: 2
I can understand your resistance to vents .But you can find some really neat vents which do not spoil the interior
roydan is offline   Reply With Quote
Venting an oven range microwave demandrew HVAC 47 03-14-2012 06:15 AM
Powder room venting mjordan76 Plumbing 3 02-26-2012 08:19 AM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 04:47 PM
Boiler room venting dontilgon HVAC 19 12-07-2009 05:07 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
