Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-26-2005, 08:18 AM   #1
venting a bathroom
What to do when the floor joists run the wrong way? The bath is on the ground floor of a two story apartment building. Original plan was to run the vent out the side of the building between the two floors, but the joists are blocking this exit. Is a side mount my only option? Are they effective?
Remodeling is offline   Reply With Quote
Old 05-26-2005, 10:11 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
venting a bathroom
The easiest and least expensive way to vent this bathroom is to install an exterior wall-mount just below ceiling joist level to vent it outside.
I would install a larger CFM fan motor unit. As far as I'm concerned, you can't install "too much" vent fan capacity in a bathroom to begin with.
The same-brand unit housings may be the same size, but get the one with the largest CFM fan motor. The CFM should be on the boxes.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Bathroom venting g1246 Remodeling 4 04-11-2007 05:30 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
help with bathroom venting fan fonda Plumbing 2 03-08-2006 09:32 PM
