Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-31-2006, 03:15 PM   #1
Vaulting my 8 ft Ceilings
I have a mid 60's rambler & I want to vault my ceilings on the main level. I looked in the crawl space & it looks like the roof is supported by the load bearing wall with 2x4's that come off the load bering wall in a y shape. How do I support the roof so I can take the existing bracing off? Do I run a beam on the ridge line of the roof with a support on both ends?
Thanks,
ALL CITY is offline   Reply With Quote
Old 10-31-2006, 09:17 PM   #2
747
registered
747's Avatar
I think the reason none of the carpenters are answering is because they don't think you should be messing with a load bearing wall. I would advise getting a Carpenter in there to take a look.
747 is offline   Reply With Quote
Old 11-01-2006, 05:33 AM   #3
General Contractor
joasis's Avatar
Pictures would help...you might have trusses above. Vaulting a ceiling isn't a DIY project.
joasis is offline   Reply With Quote
Texture coming off of ceilings mrswoodward General Discussion 7 08-16-2007 08:42 AM
8 foot ceilings -- tray ceiling? lordlang General Discussion 1 12-29-2006 07:09 PM
Raising The Ceilings propain Building & Construction 2 06-28-2006 06:33 PM
raise my ceilings this old house Building & Construction 2 10-30-2005 08:53 AM
