Vapour Barrier On One Wall Only? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-22-2008, 11:05 AM   #1
hobbsInVancouver
vapour barrier on one wall only?
Hi. My first post.
I'm putting up drywall on one wall in a room that is mostly plaster and lath. The wall i'm working on was originally wood panelling nailed to the studs. Should I bother to use vapur barrier between the drywall and insulation since no other wall in the room has a VB?
Thanks in advance,
Hobbs.
hobbs in vanvouver is offline   Reply With Quote
Old 05-22-2008, 11:13 AM   #2
Registered User
Termite's Avatar
Hi Hobbs.
It won't hurt to put a vapor barrier in that wall, but you may or may not benefit from it, depending on how much it communicates air with the other walls.
You can only deal with what you've opened up, so I'd go ahead and put it in. It certainly won't hurt to have it.
Old 05-22-2008, 11:21 AM   #3
hobbsInVancouver
Thanks much for the quick reply. I figured that's the way to go. As long as the one barrier in the room won't adversely affect the other walls, I'll throw it up. Thanks again. h
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
vapour barrier in part of room? bluejay Building & Construction 1 05-07-2008 06:31 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
How important is plastic vapor barrier on foundation wall? slatergrl Remodeling 5 02-18-2008 12:49 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
