-   -   vapour barrier on one wall only? (http://www.diychatroom.com/f15/vapour-barrier-one-wall-only-21328/)
hobbs in vanvouver 05-22-2008 11:05 AM
Hi. My first post.
I'm putting up drywall on one wall in a room that is mostly plaster and lath. The wall i'm working on was originally wood panelling nailed to the studs. Should I bother to use vapur barrier between the drywall and insulation since no other wall in the room has a VB?
Thanks in advance,
Hobbs.
Termite 05-22-2008 11:13 AM
Hi Hobbs.
It won't hurt to put a vapor barrier in that wall, but you may or may not benefit from it, depending on how much it communicates air with the other walls.
You can only deal with what you've opened up, so I'd go ahead and put it in. It certainly won't hurt to have it.
hobbs in vanvouver 05-22-2008 11:21 AM
Thanks much for the quick reply. I figured that's the way to go. As long as the one barrier in the room won't adversely affect the other walls, I'll throw it up. Thanks again. h
