Vapour Barrier In Kitchen - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-17-2013, 06:52 AM   #1
Vapour Barrier in Kitchen
I am involved in a kitchen renovation and have come across a situation regarding the vapor barrier. My house was built in 1988. The outside wall of my kitchen only has vapor barrier vertically up to where the bulkhead was (about 8" below ceiling). My new cabinets will not have a bulkhead but a a crown molding front hiding the plumbing/wiring behind it. The rim joist (with insulation) and 2nd story floor joists are exposed. I am going to replace the vapor barrier on the wall but am not sure what to do about tying it in with the 2nd story sub floor. Any suggestions?
rjf44 is offline   Reply With Quote
Old 07-17-2013, 07:04 AM   #2
Rewards Points: 252
Do your best to cut the vapour barrier around the joists and whatnot. Use staples and acoustical sealant to seal it to the subfloor.
shazapple is offline   Reply With Quote
Water buildup under vapour barrier in cold room jimboat Building & Construction 11 03-24-2011 12:52 PM
Installing New Electrical Outlet - Vapour Barrier WhIsKeY Electrical 4 12-31-2009 11:08 AM
Drylock, Typar and Vapour barrier? fubar79 Building & Construction 5 11-06-2009 11:35 AM
moisture behind vapour barrier piperboy General DIY Discussions 9 10-21-2008 12:49 PM
Is this a double vapour barrier or not? KUIPORNG Remodeling 11 09-29-2006 10:13 AM
