Vapor Barrier Against Concrete Foundation? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 11:53 AM   #1
Cape Cod, MA
Rewards Points: 81
Vapor barrier against concrete foundation?
Im going to be framing my basement. I was wondering if I will need to use a plastic vapor barrier where the verticle 2x4 studs run up against the concrete walls?
Thanks!
capecodder is offline   Reply With Quote
Old 02-13-2012, 12:18 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
In cold regions, the vapor barrier goes on the warm side of the insulation - if you're not using XPS boards. Frame the walls 1" off the concrete, not up against the concrete. Then install insulation and cover with the vapor barrier before drywall.
Note: newer methods of insulation and framing dictate using XPS panels against the concrete before framing.
hyunelan2 is offline   Reply With Quote
Old 02-13-2012, 01:04 PM   #3
Cape Cod, MA
Rewards Points: 81
Great! Thanks for the info. These XPS panels...are they something that can be purchased through home depot? or a lowes?
Thanks again!
Old 02-13-2012, 01:09 PM   #4
Registered User
Rewards Points: 5,204
That would be Case #3, possible mold and convective looping of the fiberglass without the air space, definite c.v. with the air space; http://www.buildingscience.com/docum...study-analysis
http://joneakes.com/jons-fixit-database/743
Gary
Old 02-13-2012, 03:17 PM   #5
hyunelan2's Avatar
Rewards Points: 686
Good info about convective looping, thanks. So according to that 2nd link, without XPS you should push the fiberglass all the way against the concrete. You should still frame the walls off of the concrete though, correct? Or is it also a myth that it's bad to have untreated lumber in direct contact with the concrete?
Old 02-14-2012, 12:31 AM   #6
Registered User
Concrete walls will wet the f.g. insulation degrading it's R by 66%. The air space is bad on concrete, the rigid seals the air out along with the air-tight drywall approach (ADA) and a sill sealer for an air break, it also acts as a capillary/thermal break to the slab/earth below. Canada is about the only place to still use a v.b. in basements even with their own dated literature - pp.14, 19, 29. 32, 42, 49-55, 59, read "a" and "e" and "g" there. pp 59 of article- and last paragraph.... ftp://ftp.cmhc-schl.gc.ca/chic-ccdh/..._Web_sept5.pdf
Others of interest: http://www.carb-swa.com/articles/in%...Insulation.pdf
http://libdspace.uwaterloo.ca/bitstr...c%20Thesis.pdf
http://www.buildingscience.com/docum...ent-insulation
Gary
Old 02-14-2012, 08:51 AM   #7
Thanks!
If you use low density closed cell spray foam in between the studs you do not need a vapor barrier. If you use just regular batting insulation, something i'd never use in a basement, then you need a vapor barrier on the warm side.
jasin is offline   Reply With Quote
Old 02-14-2012, 08:57 AM   #8
That's why you seal the walls before studding and putting in insulation.
Old 02-14-2012, 09:12 AM   #9
I hope the OP is is using exterior grade studs. You are not suppose to use regular interior studs in a basement.
Old 02-14-2012, 09:40 AM   #10
Rewards Points: 660
...??? Your last three posts have me scratching my bald head.
The bottom plate in contact with the floor should be treated wood, but the rest of the lumber can be regular 2x4.
Don't Drylock the basement walls, that just directs the moisture further down.
B
Beepster is offline   Reply With Quote
Old 02-14-2012, 10:19 AM   #11
hyunelan2's Avatar
Rewards Points: 686
Let me preface this by saying I'm not trying to argue that FG batts are better, just trying to understand.
So, if you are reducing an R13 fiberglass batt by 66%, you now have an ~R4.3 value. Isn't this about just as good as a 1" XPS (R5) with lower cost?
Old 02-14-2012, 10:59 AM   #12
B
If the studs are anywhere near an unsealed concrete wall they should be exterior grade. Concrete walls do get wet. see post #6 & 8
Old 02-14-2012, 12:00 PM   #13
Rewards Points: 660
If your concrete walls are going to get wet, you deal with that issue before you finish off your basement.
I have 1" XPS glued to the wall and am 2x4 framing over that with R13 unfaced insulation in between. I believe after reading over all of the "Building Sciences" links that GBR has provided that that is the current thinking on how you finish off basements. Use 2" XPS if you want to.
B
Old 02-14-2012, 11:11 PM   #14
Registered User
----- In between does not stop moisture where the studs are. Vapor barriers on the warm side below grade are not recommended. They have problems, even with SPF: http://docs.google.com/viewer?a=v&q=...oAYQmvK_bHtRKg
"That's why you seal the walls before studding and putting in insulation. " --------- sealing the walls with anything is counter-productive. This just forces the water in the concrete wall elsewhere, usually to the footing/wall joint to enter the basement with more volume now at the slab/wall joint.
"I hope the OP is is using exterior grade studs. You are not suppose to use regular interior studs in a basement."-------
You need to explain that one to me. I hope you are confusing studs with plywood = exterior/interior...
2" is better in colder locations; http://www.buildingfoundation.umn.ed...timum-main.htm
Gary
Old 02-14-2012, 11:22 PM   #15
Registered User
Cc, I would use some Grace Ice&water shield on the fire-stopping studs sistered to the layout studs every 10', per Code, with the foamboard between. Use a sill sealer under the p.t. bottom plate (capillary/thermal/air break) and for a thermal break between the fire-stop stud and the layout stud. P.t. on the concrete WALL is not required with the G.I.&.W. Be sure to fire-stop over top of foamboard/joist cavities above. http://publicecodes.citation.com/ico...002_par031.htm
http://publicecodes.citation.com/ico...9_3_sec017.htm
ADA the drywall: http://www.buildingscience.com/docum...wall-approach/
And air-seal the rims w. f.b.: http://www.buildingscience.com/docum...l_seal_rev.pdf
Gary
Repairing a concrete foundation corner. Timlo Building & Construction 4 10-11-2011 11:40 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Basement concrete foundation wall insulation question pameyer Building & Construction 0 01-28-2011 01:05 PM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 09:43 PM
Concrete Block Foundation Questions project_guy Building & Construction 1 05-09-2008 10:16 AM
