Vanity Doesn't Meet Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-24-2013, 04:42 PM   #1
vanity doesn't meet wall
I am remodeling my bathroom on a budget. This house was built in the 60's. I am putting up wood on the walls to make it look like barn wood. I tore off the existing tile that was by the vanity top on the wall and only went up 3 tile high. Now I have a space between the walls (on both sides) and the vanity of about 1 inch. What should I do to fill this gap? p.s. the vanity top curves up a little in the back. (does this make any sense ? lol)
pegzie is offline   Reply With Quote
Old 06-24-2013, 05:09 PM   #2
MarginallyQualified
Rewards Points: 2,464
Seriously reconsider this idea.
I'd suggest that you repair the wall (green board?) and re-tile.
The Following User Says Thank You to TarheelTerp For This Useful Post:
joecaption (06-24-2013)
Old 06-24-2013, 08:24 PM   #3
Rewards Points: 14,306
Got a picture?
Old 06-25-2013, 09:36 AM   #4
Sorry, but I don't want to reconsider. I was just going to take the wallpaper down and paint...but, as you can see, there is 5 (yes 5) layers of wallpaper and I am sick of trying to peel it all off. Plus, no primer/paint under the original paper. grrrrr!!!! Here is a picture...thanks
Old 06-25-2013, 09:41 AM   #5
Location....small town USA. So if you are from the "big city"...I'm sure this is not your taste in decor. But it is mine.
Old 06-25-2013, 10:30 AM   #6
Rewards Points: 44
How thick is the wood?
Are you going all the way to the ceiling?
Dan
djlandkpl is offline   Reply With Quote
Old 06-25-2013, 11:45 AM   #7
It's that real thin Cariboo solid wood plank paneling that is tongue and groove.
Old 06-25-2013, 11:46 AM   #8
oh and yes to the ceiling.
Old 06-25-2013, 12:04 PM   #9
MarginallyQualified
It's not about "decor" or taste.
It's about having wood in a bathroom.
As to the wallpaper... hire out the PITA or put up thin sheet rock.
Old 06-25-2013, 12:59 PM   #10
Wink
I got it! I had the local lumber yard rip a board down and I will put that in the gap. thanks
Old 06-25-2013, 01:19 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
pegzi....what the guys are trying to tell you is that the wood will absorb moisture....it does not do well in damp bathrooms....looks good for a short time....note....short time.
The guys are just trying to prevent you having to do it again before you want to.
The Following User Says Thank You to ddawg16 For This Useful Post:
joecaption (06-25-2013)
Old 06-25-2013, 06:17 PM   #12
Metal Roofing
Rewards Points: 600
Wallpaper that looks like wood! Solves our conerns and yours.
My work here is done
AndyWRS is offline   Reply With Quote
Old 06-26-2013, 07:06 AM   #13
Thanks for your help! there are just 2 of us at this house and only one takes a shower in this bathroom and he leaves the door open and the vent on so I think that it will be just fine. Thanks again!
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 09:48 PM
small gap between vanity and wall, how do i screw it in? cantgetenuff Building & Construction 8 03-09-2011 11:15 AM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
