-   -   using vinyl flooring for tub walls? (http://www.diychatroom.com/f15/using-vinyl-flooring-tub-walls-29362/)
squarepeg 10-04-2008 12:26 PM
Have doublewide bathroom to repair. Walls out of square, and most tub surround kits have seems or excrusions where faucets are located for 27" x 54" tubs.
1-IF DOABLE???....has anyone ever used vinyl flooring to cover bathtub walls?
2-What type of vinyl did you use ?
3- what type of glue?
4-Can I glue directly to old paneling if cleaned up, or do I need to install green board and glue it to that?
5- How long does it last? thanks
Ron6519 10-04-2008 05:55 PM
If there is an associated shower in the tub,no. This solution in a tub only environment might last a short time. This would not be on my list of possible solutions.
Ron
huntergreen 03-29-2011 12:22 PM
using vinyl lanoleum as tub surround
A friend of mine has used linoleum as a tub surround for over 15 years it is cheap and very easy to install. Two years ago they replaced the flooring in the bathroom and decided to change the linoleum around the bathtub, there was no mold, mildew etc. as long as you use the thicker vinyl linoleum and is pliable some of the cheaper linoleum break when you bend it. Every place I look they say don't do this but you can it's easy, cheap and looks good.
tcleve4911 04-27-2011 07:01 AM
What are your corner and trim details?
How do you finish off the edges?
Never heard of this one but, hey......if you say so......:huh:
tcleve4911 04-27-2011 07:13 PM
............another Newbie gone..........
