Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-18-2012, 06:55 PM   #1
Used the wrong nails.
So I just discovered that I bought and used the wrong nails for framing the majority of my basement. I went to pick up more nails today, knowing I needed 16d nails and I thought they looked much bigger than the ones I had at home. I used 10d 3inch nails... 2 in the top plate and 2 in the bottom plate.
What do I do now? They are walls that are against the concrete. Will the walls be strong enough or should I add a nail or do entirely new nails in them which would suck. But I just was interested in the possibilities.
Also, I feel really stupid already because I knew what to buy but some how bought the wrong thing, probably because they are labeled exterior framing nails and I switched boxes...
ndmeier is offline   Reply With Quote
Old 02-18-2012, 07:09 PM   #2
10d's are used in most new construction today. you will be fine, stop worrying.
framer52 is offline   Reply With Quote
Old 02-18-2012, 07:11 PM   #3
8d and 10d is about all I ever use.
Old 02-18-2012, 07:12 PM   #4
Awesome, so there shouldnt be any problems with inspections or anything like that? You guys are my heros. Felt like a complete ass for about an hour when I brought those other nails home.
Old 02-18-2012, 07:13 PM   #5
10d thats ok it won't hurt a thing....as mentioned used by alot today...
Old 02-18-2012, 07:15 PM   #6
Do you expect the inspectors to pull a nail to look at it??
Old 02-18-2012, 07:21 PM   #7
Only nails I've ever had them look at is hanger nails. Some inspectors look for a grade stamp on the nail.
They also look for nail count. Two nails in a stud will raise a red flag.
Old 02-18-2012, 07:25 PM   #8
We I figured I could get away with it but those nails look like railroad spikes by comparison. But thanks everyone
Old 02-18-2012, 07:30 PM   #9
Well I'm not sure how they could count anything since they aren't toenailled so I think ill be okay
The Following User Says Thank You to ndmeier For This Useful Post:
ben's plumbing (02-18-2012)
Old 02-18-2012, 11:40 PM   #10
Moderator
I hope the nails in the p.t. bottom plate are hot-dipped galvanized..... or a plastic vapor barrier under the slab at least.
Gary
Clothes taking longer to dry?
Old 02-18-2012, 11:42 PM   #11
They are hot dipped galvanized, I did do that part right atleast! I did research on the right ones to use but just screwed myself at the store I don't know what I was doing/thinking.
Nails - what size(s) to use for light frame construction? J S Machine Building & Construction 5 01-18-2011 04:49 AM
33º vs 35º Nails Dilemma banzaitoyota Tools 1 12-28-2010 07:44 AM
Basic questions about using nails. darsunt Carpentry 8 12-24-2009 02:29 PM
Type of nails for exterior trim bluefitness Building & Construction 2 12-07-2008 09:01 PM
Deck nails jimgibson Carpentry 12 10-09-2005 03:22 PM
