Uneven Carport Floor ? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 09:16 AM   #1
uneven carport floor ?
My husband added on a garage to the existing house/carport. He has now closed in the carport to try to create another room. The slab is not level and slopes. He is wanting to place a plywood sub floor over this but then it will cause the existing backdoor to be approx 6 inches lower then the floor. To open the door he will have to have a sweep section of the floor to continue to be the original concrete and then it will go into the sub floor. This appears to me to be causing a place that will be easy to trip, hard to clean and an unhandy design. Do you have another suggestion.
Thank you
rcrowe@ktis.net is offline   Reply With Quote
Old 02-22-2012, 09:37 AM   #2
Rewards Points: 13,458
Some pictures would sure help. Hard to understand some of your post.
Plywood should never be installed directly to a slab floor.
Some suggestions for a very uneven concrete floor psilva8 Concrete, Stone & Masonry 17 02-25-2012 11:45 PM
Uneven hw floor to vinyl transition joemontana16 Flooring 0 03-10-2010 10:10 AM
Help -my floor joist are drastically uneven jgallup Flooring 2 10-28-2009 08:17 PM
floating floor boards over uneven tiles joey44 Flooring 8 01-05-2009 08:58 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 08:07 AM
