Tyvek, Insulation Or Both - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 01:35 PM   #1
Tyvek, Insulation or both
I've researched this for the past week and still can't come up with a definitive answer. I've decided to let my decision rest on the responses from this forum.
Re-siding house. OSB, flanged windows (not replacing them), replacing front door/deck door (french). I am using tyvek flexwrap/straightflash flashing system on both doors and over the window flanges.
First question, do I go tyvek and insulation (1/2" dow super tuff r)? Just tyvek? Or just insulation taped at the seams?
Second, since I am replacing the doors, should I install the insulation sheets all the way to the rough opening, or install the door first and butt the insulation to the brickmold? I don't know how well the straightflash will adhere to the insulation.
BirmJam is offline   Reply With Quote
Old 04-13-2012, 07:39 AM   #2
Depends on where you live. Insulation on the outside of the house must allow moisture to get out, or you will have moisture trapped in the walls, NOT good. Tyvek is desighned to allow moisture thru from the house, but stop rain/wind, so yes to tyvek.
Old 04-13-2012, 07:50 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Where is the home?
In terms of order, there are multiple schools of thought on the arrangement.
I prefer the tyvek to be the last layer but it is somewhat dictated by the placement of the windows.
If they windows are and inside (i.e. inside the foam) most will put down tyvek, then foam.
I would also recommend a non-foiled faced foam as that is a vapor retarder (Class I) at that point. That foam wall will not allow moisture out.
Old 04-13-2012, 10:28 AM   #4
Originally Posted by Windows on Wash View Post
Where is the home?
I am in a Mixed Humid zone roughy 30 miles north of Philadelphia which I believe is zone 5?
I now plan on furring out the existing windows with the new doors to make the surface depth even with the insulation. Was at lowes today and they had both foiled and non foiled sheathing in 1". There was a lot less non foiled on the shelf which makes me think that installers in my area go with non-foiled insulation over foiled.
Old 04-13-2012, 03:02 PM   #5
How would I attach it to the foam?
Old 04-13-2012, 07:10 PM   #6
Registered User
Rewards Points: 4,914
What type of cladding?
Gary
Old 04-13-2012, 08:28 PM   #7
Gary
OSB, 1" Insulation then Tyvek.
Old 04-13-2012, 11:29 PM   #8
Registered User
Sorry, by "cladding", I meant siding....
You don't want foil-faced foamboard; "Vapor management" pp.14: http://www.buildingscience.com/docum...ting-sheathing
As per that article, I would install the H.W. on the OSB, using a "Stucco wrap" for the air space, then the foamboard over it. http://www.buildingscience.com/docum...d%20in%20walls
This will prevent "wind-loading" of the H.W.
Depends on the siding..... if you need a "rainscreen" system or not. You have about 40" rain annually.
Gary
Old 04-14-2012, 08:36 PM   #9
I am using vinyl siding.
Where can I purchase stucco wrap? I have read a lot of people say that vinyl siding is not a complete water barrier, wouldn't I want to use the H.W. on top of the insulated sheathing, especially since the insulation will not be foil-faced and therefore absorb water?
Old 04-16-2012, 12:54 AM   #10
Registered User
Be sure to pay attention to details when applying it- reverse laps, etc.http://www.buildingscience.com/docum...d-wall-systems
http://www.buildingscience.com/docum...m-shrinks/view
The closed-cell (XPS) is very dense, absorbing minimal water; http://msdssearch.dow.com/PublishedL...romPage=GetDoc
You need the stucco wrap between the foam/OSB to dry the OSB if it ever gets wet. Read "Practical recommendations." at end, notice the second and third ones: http://www.nrc-cnrc.gc.ca/eng/ibp/ir.../ctus-n32.html
Gary
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 11:04 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
