Two-sided Fireplace - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 09:00 PM   #1
two-sided fireplace
I have a fireplace that is open on two sides that currently I use to burn wood. I would like to convert it to a gas-burning fireplace. Gas Inserts are only open on one side. Is my only option to remove the fireplace and install a new one? Or can I get away with installing a firebox? Or is that the same thing?
Holly31 is offline   Reply With Quote
Old 09-04-2010, 05:03 PM   #2
Concrete & Masonry
Rewards Points: 568
Call a fireplace store or contractor & ask them about a "gas log set."
jomama45 is offline   Reply With Quote
Old 09-14-2010, 12:49 PM   #3
Are you wanting to use it for a heat source or decoration?
there are a couple things you can do either way. Close one side and use a insert or find someone who KNOWS GAS PIPING WELL and have them modify a insert for 2 sided use.
I also have a double sides fireplace and use it allot in the winter. I am planning on converting it to gas in the future. However I am NOT going to use natural gas but building a set of gas burners for Propane use.
I am installing a large propane tank on the side of the fireplace in a enclosed bench seat box and running 2 long length gas grill burners across the floorand using the permanent heat rocks to cover the burners makes it look nice and helps radiate the heat. I am also thinking of installing them into a sand box to have a more of a "artistic" surface fire vs utilitarian.
No mattre WHAT you do it make sure that you follow the 3 S's in gas pipe safety.
Sealed with no leaks
Secluded AWAY from heat
Secured to prevent rupture due to wear from vibration.
urborn2die is offline   Reply With Quote
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 06:02 PM
3 sided fireplace top Dody General DIY Discussions 2 03-11-2009 02:55 PM
How to handle the corners of a three sided fireplace - drywall-wise? vsheetz Carpentry 3 02-27-2009 09:28 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
