-   -   Turning a tile shower into a one piece shower... (http://www.diychatroom.com/f15/turning-tile-shower-into-one-piece-shower-39858/)
chimera 03-07-2009 05:19 PM
Hi my name is Phillip and I am currently remodeling a older bathroom in my house... I am 20 so please cut me some slack if I dont know what you are talking about lol... Neways this is the first time I have ever remodeled a shower and I had a few questions about it... I currently have a tile shower and the floors are cracking out from under it and I was wanting to know what all I need to do to prep it for a one piece shower... Do I need to remove the tile from the wall before installing the one piece? What do I need to do to prep the floor for the shower? When I tore up the floor I expected to find backer board but instead what I found was concrete (I think) and a hole leading to the bottom of my house, lol . How do I go about supporting the new shower? and how do I replace the floor joists... Any help would be appreciated... I know I am probably way over my head but I ususally am, haha, I refuse to hire someone, I will figure it out one way or another but I will get it done, I find that persistance is key... I have yet to meet the job I cant tackle...
thank you
phillip
PS here are some pictures of what I am dealing with...
http://i34.photobucket.com/albums/d1...8/DSC01010.jpg
http://i34.photobucket.com/albums/d1...8/DSC01008.jpg
Rivethead 03-07-2009 10:43 PM
What's under the "concrete" since you have a convenient hole available to check.
chimera 03-08-2009 09:03 AM
it looks like wire mesh and I can see the support beams to the floor directly under the mesh, one of them is rotted away so i know it will have to be replaced... I found this out when I crawled underneath the house... I am gonna continue tearing out the floor since I know the beam has to be replaced to support the new shower... I will post up pictures when I finish tearing it out...
chimera 03-08-2009 10:09 AM
okay so what i though was a wire mesh material is a rotted out support beam that has basically turned into a fiber like material that crumbles whenever you touch it... It seems that there is a material covering the support beams that is about an 1/8" thick and looks like a cheap type of ply wood that has now been rotted and is about the consistency of wet card board...
http://i34.photobucket.com/albums/d1...8/DSC01014.jpg
http://i34.photobucket.com/albums/d1...8/DSC01016.jpg
http://i34.photobucket.com/albums/d1...8/DSC01015.jpg
chimera 03-08-2009 11:26 AM
okay so i got the floor removed and now I need to replace the joists that are in the floor.. Should I go ahead and take the tile down off the wall or should I wait until I get the new joists in place? I am not quite sure how this works... any help would be appreciated...
thanks
phillip
http://i34.photobucket.com/albums/d1...8/DSC01019.jpg
http://i34.photobucket.com/albums/d1...8/DSC01018.jpg
Rivethead 03-08-2009 02:16 PM
What a mess - yeah understatement of the year right.
I'd do all my tear out first - just to be sure you don't run into other issues.
How big is that drain line? It looks like 3/4 or 1 inch copper pipe.....
chimera 03-08-2009 06:31 PM
omg understatement of the century is right. I got one of the walls all taken out and the floor removed... The drain pipe is an 1 1/4"... I am covered in filth from head to toe and now my friend i do believe I will be going to take a shower... I will keep you updated on my progress...
Ron6519 03-08-2009 08:52 PM
This seems to be the beginning of a gut job. That damage is going to radiate outwards to the areas that look okay.
Ron
Rivethead 03-08-2009 09:38 PM
Oh the memories your bringing back of our first house - same project except around a tub.
Your doing fine - you can do this. But, I will say, when you decided to take on a first large remodeling project - you sure picked a winner....
What condition is that header in. Jamb a screwdriver in it and see how solid it is.
chimera 03-09-2009 12:12 AM
This may sound like a dumb question but whats a header?
Rivethead 03-09-2009 04:41 AM
That wood plate that's running along the brick - that your floor joists (or their remains) are fastened to.
chimera 03-09-2009 05:27 AM
the header board is in fine condition... I decided I am gonna sister the floor joist and use joist hangers vs the way that it was originally done... The way it was originally done was they nailed a 2x2 to the header and notched the joists around it for support... The 2x2 is in poor condition so I am gonna replace it with joist hangers... Then I will sister an 8x10 on both sides of both of the original 8x10 joists...
bjbatlanta 03-14-2009 02:30 PM
An 8x10??? Do you mean a 2"x8"x10' (or 2"x10"x8' perhaps)? Sounds like you're on the right track. Are you sure a one piece shower will go through the doorway? Bathroom doors are often 24" and showers are over 24".....
