Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-17-2012, 02:49 AM   #1
Turn Bathroom into Bath/Shower?
I have a bathroom that is very basic, toilet and sink. That's it. I could really use a shower in there but there is not room to add a separate shower. My thought is to add a shower head in the room and a drain in the floor and leave the sink and toilet where it is.
My immediate thoughts are that I would need to change out the floor and turn it into a shower pan. I would also need to take down the dry wall and replace it with cement panels.
I would also need to add in a drain. Can I just put in a T off of the drain for the toilet?
What else am I missing? Or am I crazy for thinking of this?
There is a ventilation fan in there already to suck the moist air out.
tunaman is offline   Reply With Quote
Old 10-17-2012, 04:57 AM   #2
Super Moderator
How small is this powder room?
I suggest you look at modern waterproofing methods---Schluter makes a surface membrane that can waterproof the existing walls--
Latacrete makes Hydroban that is a paint in waterproofer--more details--size first--
Old 10-17-2012, 07:50 AM   #3
I see no way you can legally do this. A bathroom has to have at least one receptacle, which obviously you couldn't have in a shower. Same for the light switch, but that could I suppose be moved outside. There are also serious code requirements for a light fixture in a shower. You'd also no longer be able to heat the room.
Old 10-17-2012, 08:25 AM   #4
REDRUM's Avatar
reminds me of a travel trailer bathroom....
not up to code but could you ... use waterproof led lighting, or exterior lighting (with switch outside room), maybe a waterproof enclosure for an outlet, or mount the outlet outside the room next to the switch.. if the room is small enough the coord length shouldn't be an issue.
i dont know about the drain being shared with toilet
REDRUM is offline   Reply With Quote
Old 10-17-2012, 10:32 AM   #5
I think it's a great idea if you can manage the logistics of it. I lived in Taiwan for three years and all the bathrooms are like that. Sometimes there'd be a tub but they would still have a central drain and shower head. Made it really easy to keep clean.
MissKat is offline   Reply With Quote
The Following User Says Thank You to MissKat For This Useful Post:
mae-ling (10-18-2012)
Old 10-17-2012, 12:57 PM   #6
That's great, but would never fly in the U.S.
Old 10-18-2012, 02:22 AM   #7
Seriosuly? You are forced to have an outlet in a bathroom? How about those ceiling fan/light combos? You cant have one of those in a shower? Heating the room is not a problem. Im in a climate in the US where I can have my windows open probably 3/4s of the year.
With regards to the room it is a 6.5 x 6.5' square. There is currently one door, a sink, and a toilet against the same wall as the sink. The door is in the wall adjacent to the wall with the sink and toilet on it. The door opens to the left, and the sink is immediately on the right.
My thought is to put a drain right in the middle of the room and add a shower head on the wall opposite the toilet and sink and have it shoot down into the middle of the room. I was thinking to line the walls with cement board, put in a shower pan and then add tile on the walls and ceiling. This is on the ground floor so I would be cutting out the concrete foundation to add the drain Foundation is 6" of concrete.
Old 10-18-2012, 04:34 AM   #8
Super Moderator
It's an idea that most people won't like---and might not meet code---
But that was not your question---can it be done?
Sure---Gut the room----remove the floor---add a drain--shower mixer ---slope the floor----rock the walls---mesh all corners---seal everything with Hydroban--three coats ---tile---reinstall toilet and sink---add a water proof door---
Think of it as a shower with a toilet inside---
I would not add electrical outlet---odd in this country--but it's your place---
Old 10-18-2012, 08:36 AM   #9
Yes, seriously, code requires at least one outlet (GFCI protected) in a bathroom. And the typical ceiling light/fan combos are not rated for a wet location, which is what you'll be creating. Can your project be done? Yes. Will it be legal? Not a chance. Might hurt your home's resale value too.
Old 10-18-2012, 10:01 AM   #10
GBrackins's Avatar
plus I'd hate to know that after I dried myself off I'd have to dry the toilet off too ..... good way to keep it clean though
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-18-2012, 10:18 AM   #11
England uses this idea as well.
Water does not need to get all over everything, locate shower head in right place and have a wrap around curtain that covers the sink and toilet.
Be sure to have a great exhaust fan.
Do some research on it.
mae-ling is offline   Reply With Quote
Old 10-18-2012, 12:54 PM   #12
Stuck in the 70's
Blondesense's Avatar
How ya gonna keep the TP dry?
Old 10-18-2012, 12:58 PM   #13
Experienced
Jackofall1's Avatar
With the right timing you wouldn't need it!
Trouble with three switches in bathroom chris54 Electrical 21 08-12-2012 01:17 AM
gutting bathroom debiasio Remodeling 30 02-17-2011 03:32 PM
what type of drywall for a bathroom with no bath/shower? BlueBSH Drywall & Plaster 3 12-15-2010 11:55 AM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 09:00 PM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
